what cam for PRC ls6 heads .
Old Jun 22, 2011 | 06:48 AM
Dossary M's Avatar
Default what cam for PRC ls6 heads .
hi
Hi all ,,
My problem that I have a holden commodore with ls1 , know I am going to upgrade the engine with PRC ls6 heads & 102 FAST / 102 TB . I am confused with the cam should I buy . I have the V3 cheater cam on with stock ls1 manifolds with 80” BBK TB and OTR sureflo intake 3.73 gear . is it going to work well if I used the same cam or not ..
Please help.
Old Jun 22, 2011 | 07:01 AM
Darkman's Avatar
By "stock LS1 manifolds" do you mean stock exhaust manifolds? If yes, I would stick with that cam. If you have headers you could go to a different cam.
Old Jun 22, 2011 | 08:13 AM
Dossary M's Avatar
yes i have full exhaust system but stock ls1 manifolds but my question is would it be a result if i use the V3 cheater cam with the full CNC ls6 heads and 102 FAST maniflds /102mm TB. cas i dont want to drive a big hard aggrasive cma.
Old Jun 22, 2011 | 08:20 AM
PREDATOR-Z's Avatar
It will be fine. It will drive as it does right now, but better, faster, more responsive.
Old Jun 22, 2011 | 08:24 AM
Darkman's Avatar
Yes you can. I have stock exhaust manifolds, high flow cats, and a very similar cam with a set of Trick Flow 215s and a FAST 102 intake/90mm throttlebody. It has balanced torque and horsepower levels (407 rwhp/ 393 rwtq) and drives like stock except for more power.
Your setup with the 102mm TB may be a little harder to tune, but should work well.
Old Jun 22, 2011 | 08:29 AM
Dossary M's Avatar
what HP do you think it will go with the new set up . cause know with the old one i made 385hp/376Tq.
Old Jun 22, 2011 | 08:33 AM
Dossary M's Avatar
so at the end it will worht to go with this set up .
Old Jun 22, 2011 | 09:15 AM
Darkman's Avatar
I cannot guess what your horsepower or torque numbers might be. My results were in a 2005 CTS-V that has parasitic driveline loss of almost 20%, which is much higher than others. On the other hand, I suspect my heads are better.
Old Jun 22, 2011 | 10:18 AM
Dossary M's Avatar
ok , on more thing , do think it is ok if i re uesed my Cometic gasket and what you think in 040" gasket . also what fule injectors you recommend to use know i have my friend's accel 30lbs . what do think of that
Old Jun 22, 2011 | 10:25 AM
Dossary M's Avatar
thank you for your help my friend.
anyone please i am still waiting
Old Jun 22, 2011 | 10:41 AM
Darkman's Avatar
I am still using my stock injectors which I believe are 26lb units since my tuner has not said anything about needing larger injectors. I assume, therefore that 30lb-injectors would be adequate.
I am not sure which head gasket to use with that head. You might check with Texas Speed since they sell that head as well as head gaskets.
Old Jun 22, 2011 | 11:09 AM
Dossary M's Avatar
thanks
Old Jun 22, 2011 | 06:21 PM
garygnu's Avatar
don't reuse the old head gaskets.what valve springs do you have on your current heads?how many miles?I would get bigger injectors ,at least 36 lbs.get the thinner head gaskets if you have enough PTV clearence,and it won't screw up your valve train geometry .read up on lifter preload to figure out the correct length for push rods.or ask TSP which parts you need. .do you have stock rocker arms?get comp trunnion bearings for them.
Old Jun 23, 2011 | 03:32 AM
Dossary M's Avatar
I installed the 040 cometic head gasket 4 month ago for I think 2000KM .My new lS6 heads 64cc Chambers comes with Dual Valve Springs 650” as same as the valve Springs on my old setup from TSP onmy ls1 heads.
Yes I have stock rocker arms and I think I will use my old setup push rods 7.400” from trick flow.
so what do you think .
Old Jun 23, 2011 | 03:37 AM
hookngo's Avatar
Nice ssetup
Old Jun 23, 2011 | 03:39 AM
Dossary M's Avatar
so dose it worth to go with v3 cheater cam . with modes i mentioned
