My New ls1 setup with TSP PRC ls6
I am confused in the cam. I have the V3 cheater cam , OTR sureflo intake 3.73 gear is it going to work well if I used the this cam
on more thing , do think it is ok if i reuesed my Cometic head gasket and what you think in 040" gasket . also what fule injectors you recommend to use know i have my friend's accel 30lbs . what do think of that
I installed the 040 cometic head gasket 4 month ago for I think 2000KM for my old setup .My new lS6 heads 64cc Chambers comes with Dual Valve Springs 650” have stock rocker arms and I think I will use my old setup push rods 7.400” from trick flow.
so what do you think .
