Piston help
Old Jun 25, 2011 | 04:38 PM
ItalianZ28Stallion's Avatar
Default Piston help
I'm looking to get a new set of pistons but im not sure what brand i should go with and or if certain brand's have domed pistons. I would like to be around 11.1CR here is all the parts i currently have are ported fast90/90 combo 42Lbs injectors,06z06 243 heads stock, custom 228/236 58x/6xx cam on a 111lsa with a 110icl, new 675 springs and pushrod's, ls2 timing chain, ls7 lifter's, slp maf scorpion rockers. im missing some other thing's all the help and advise would be very help full thank you.
Old Jun 25, 2011 | 06:00 PM
khaotic's Avatar
their are several piston makers Je diamond wiseco any of those work great I have been running Je for years no issue wiseco piston are to be the hot lick right now, but your gonna need more info to determine piston to get the compression you need. Make sure you cc the heads or take to machine shop to verify how far are the piston out of the hole on the block now and head gasket thickness, on one of my setups 62cc heads ls6 with a .045 head gasket with piston out of the hole .012 gave me 11.1 so you will need that info before ordering pistons
Old Jun 25, 2011 | 07:46 PM
racer7088's Avatar
Wiseco has some domed pistons for the stock bore and stroke which have a solid dome so you can take some off the top to make less compression if you want.
