lifter preload question
Old Jun 26, 2011 | 10:56 AM
74yellowmav's Avatar
Default lifter preload question
Ok guys I'm having some random noisy lifter ticks
I've got a lunati cam and springs with stock rockers and pushrods
From zero lash I have a little less the 3/4 aturn on the rocker arm bolt till full tourqe is this enough? Too much?
Old Jun 26, 2011 | 11:08 AM
Darkman's Avatar
The accepted range is from 1 1/4 to 1 3/4 turns.
https://ls1tech.com/forums/15069830-post21.html
Old Jun 26, 2011 | 11:12 AM
Thanks I've searched for a hour and couldn't find it, any ideas how much longer they will need to be?
Old Jun 26, 2011 | 11:18 AM
Darkman's Avatar
At least 0.25" longer -
"For an example, if you use a 7.400" pushrod and come up with 3/4 of a turn, you will need at least .025" longer pushrod to get into range. If you end up with 2 1/4 turns, you will need one .025" shorter..."
Old Jun 27, 2011 | 07:07 AM
Sorry I had my stupid hat on yesterday, having to surf the net from my crappy phone makes me miss some things from time to time, I ordered some 4.125 pushrods last night
Old Jun 27, 2011 | 07:29 AM
Darkman's Avatar
..I ordered some 4.125 pushrods last night
I somehow doubt that.
Old Jun 30, 2011 | 11:23 AM
The 7.425's gave me exactly 1.5 turns preload
Most of the noise is gone still have one on the driver side giving some noise I think its a lifter issue
Old Jul 1, 2011 | 07:20 AM
The problem was the oil pump o ring, swapped it and gained a load of oil pressure and noise is gone
Old Jul 2, 2011 | 12:09 AM
speedtigger's Avatar
Old School Heavy
What was your oil pressure before and after?
Old Jul 2, 2011 | 07:24 AM
20-25 idle before, 40 to 3k, sometimes would go 60 but rare occasion with 10w40 and lucas
Now I have 35 at idle and 60+ at 3k with 5w30 with nothing added
