differences between cam lobes
Old Jul 4, 2011 | 08:01 AM
Floorman279's Avatar
Default differences between cam lobes
not too familiar with cam lobes.....what makes each of the following unique? are they all comp lobes?
xfi
xer
lsk
xe
lsl
Old Jul 4, 2011 | 09:38 AM
DrkPhx's Avatar
Those are all Comp Cam lobes. Each one has different ramp rates and valve lift; some more aggressive than the others. Do a search on here and you will find a lot of good information about the different lobes. You should also get a copy of the Comp Cam Master Lobe catalog as well.
Old Jul 4, 2011 | 11:19 AM
J1D2warrior's Avatar
Just call comp and ask for a free lobe catalogue. It will explain the ramp rates and give an explanation of the different lobes and what they are designed to do.
Old Jul 4, 2011 | 01:20 PM
JPH's Avatar
JPH
Originally Posted by j1d2warrior
just call comp and ask for a free lobe catalogue. It will explain the ramp rates and give an explanation of the different lobes and what they are designed to do.
^^^ +1. But stick with a XER or LSL lobe for general purposes and you won't go wrong.
Old Jul 5, 2011 | 02:04 PM
ok thanks gor the adivice
