R 799 heads any good how bout the 4.8's?
Ok so I made up my mind and decided that I do not want to drive my car anymore due to the car burning more oil than I thought after I swapped camshaft. Im pretty sure its the valve seals cause I did the mistake of leaving the stockers on while swapping cams, anyways I dont really see myself vesting time or money in the stock heads for no extra power really piisses me off. I see that a guy on the forum posted 799 castings as the same as 243's is this true? Also a guy here at the local machine shop has some 4.8 casting which are 8xx I forgot the casting number as it's almost like the stock cast number on my stock ls1 heads are these heads any good? I know some of you may say get prc from tsp but really dont have the cash at the moment and also where could I get the centerbolt valve covers with racks since I have the 98' ls1 and each coil pack is bolted seperately in case I do come up on different set of heads. Long story short which heads out perform stock ls1 heads?
The 799 is the casting number for vendors that make heads for GM and as he said they are identical to 243 castings. The 799/243 will NOT add compression to your LS1 unless your heads have a larger combustion chamber. They will if installed on a 4.8/5.3l though. The 243/799 will outperform your original heads and get you the perimeter bolt valve covers as well. The heads you probably ran into on the 4.8l are the 862 castings which also come on the 5.3L's . 862 heads have 61cc chambers and the 799/243 have 65cc chambers.
^^This. Also slappin a 67cc head on a 5.3 motor is not gonna give you comp. its gonna take it away cause your added a larger chamber head to a smaller bore block. Kinda like sticking a 317 head on a stock LS1. Thats why people use the 5.3 head with a smaller chamber to get a comp. bump on a stock LS1.
So basically his entire post was false information.
The 799 is the casting number for vendors that make heads for GM and as he said they are identical to 243 castings (depends if LS6 243s or not). The 799/243 will NOT add compression to your LS1 Yes they will unless your heads have a larger combustion chamber Wrong quite the opposite. They will if installed on a 4.8/5.3l though (wrong again). The 243/799 will outperform your original heads and get you the perimeter bolt valve covers as well. The heads you probably ran into on the 4.8l are the 862 castings which also come on the 5.3L's . 862 heads have 61cc 61.5 chambers and the 799/243 have 65cc 64.5 chambers.
