Pulled heads, need opinions.........(pics inside)
i almost have everything i need to complete the build, im just waiting for the seats, locks and seals to come from comp. i had purchased a set already but they didnt fit, the correct ones should be here in about five days, hopefully sooner. im really excited because i picked up an LS6 intake lastnight, i paid 300$
for it but the guy held it for me for almost a week, he was local and it only has like 40k on it. i know 300$ is a lot of money but i didnt want to try and talk him down after he held it so long for me. im just happy to have one
its off of an 04' gto. the guy pulled it off to put a fast 102 on, he had patriot cnc'd 243's with ALL the boltons, it was very nice. I could have sold you a LS6 intake, but it probably wouldn't have fit.
I found out the wrong seats were installed on my heads so I ended up ordering a set of the 4695's myself this morning and a shim kit.
Hope to see it back together soon.
Make sure you get your spring height setup right. As mentioned talk to someone knowledgeable about it. I've learned a lot in the past week about it.
thank you for the compliment
, yeah i started off just going to change the head gasket and then once i was there..........i started thinking about changing this and changing that.....well, you know how it goes
next thing you know you need that for this and this for thatunfortunately, no i never did find out where the coolant leak was for sure but when i took my stock heads into the napa they said they could tell what cylinders it was because it was severely warped inbetween cylinders 2 and 4....... i still want to get a straight edge and check my block deck surface just to make sure thats within spec. heres my theory, (fwiw lol) the stock heads where stock deck height when i took them to the machine shop, so someone didnt resurface them when they did the rebuild. i dont think the passenger head ever sealed properly inbetween cylinders 2 and 4 (thats why #2 is so clean)........also because the previous owner was only able to get like 500 miles (give or take a few) on the rebuilt motor before it started overheating. (cause of blown headgasket).
i dont know how accurate that theory is and im not saying thats what i believe 100%, thats just the best i could come up with given the circumstances and my (very basic) knowlegde.
any opinions are appreciated
what seats were installed on your heads lilj and what springs do you have? i see you ordered a shim kit..... do you think i should have ordered a shim kit too? i was just going to put them on and measure installed height. i thought it would be ok since im using basically the whole comp cam kit? i have been reading a little bit about spring installed height and coil bind but between that, measureing for pushrods and putting everything back together
if you have any tips i'ld appreciate it. thanks for checking out my thread!
Comp suggests the 941 springs for your cam which has a closed pressure of 130 and open of 358. Reducing the height to 1.75 on the 925's would put you closer to what they suggest. Yes you will have a little more closed pressure but your open pressure would be a lot better IMO as it would be able to control the valve better.
Just putting the springs in at 1.81, even those are bad *** springs, you won't be using enough of the spring to control the valve train.
Lowering your install height, reducing it from 1.81 to 1.75 will also change your retainer to seal clearance because the valve seat will be closer to the retainer which can prevent the seal being driven down on the guide as far. However with your cam only having .522/.529 I highly doubt you will have any retainer to seal issues especially if you are using the correct retainers/seals. But it's always important to check. That's one of problems I'm having is I was sent the wrong retainers.
I hope this helps some and makes sense.
so basically i need a .060, right? lol....... do they sell them at part stores (autozone, pepboys) or do i need a special/certian spring shim from comp cams because im using there double springs? thanks for the help j.
flintwrench, is there any way i can check the radiator? i've flushed it out with a hose.....could something still be clogged, i really dont want this to happen again....
im confused.......these are the ones im looking at. are these the correct ones?
http://www.summitracing.com/parts/CCA-4753/
fits in the spring pocket yet clears the guideboss diameter. Obviously it goes
under the spring seat so a hardened shim is not needed.
That's the shim kit comp calls for. That's what I ordered. Why they aren't the same diameter I don't know.
1.80=145lbs
1.75=165
1.70=185
1.65=205
1.60=225
1.55=245
1.50=265
1.45=285
1.40=305
1.35=325
1.30=345
1.25=365
1.20=385
1.15=405
The difference between 1.80(spring uncompressed/valve closed) and 1.15(spring compressed/valve open) is .650 roughly. Which is the max recommend lift of that spring.
To find out how much spring pressure you will have at any given lift is take the install height minus the lift of your cam. So w/ a 1.80 install height minus the .529 lift of your cam puts you at 1.271 which is roughly 345lbs. You won't get any more spring pressure with at that install height because you aren't compressing the spring anymore.
Now if you reduced your spring height to 1.75 it has 165lbs closed. Now take the lift of your cam minus the new install height. 1.75-.529=1.221 At that height the spring pressure is roughly 365lbs. By reducing the install height you are basically making the spring shorter which increases the pressure. All the valve spring knows is it's getting compressed not how it gets there.
So you can check to see what your pressure would be with any install height in theory. However in practicality there's a point where you can run too much install height and start wearing the spring out. At that point a different spring with different rates may be needed.
Hope that helps some.
thanks lilj for all the info. i get exactly what you are saying now! i think im going to call the machine shop that rebuilt the heads and see what they think about them doing the shims or just ordering the comp 4753's. im glad those seats didnt work out, because if they did i would've had everything installed on the heads and possibly have had the heads on the car. Then i would have found out i needed these shims, lol. that woulda sucked big time!
targa, thank you for the advice........ im going to call the shop the did the heads and see what they charge for something like that. also quick question.... why wouldnt you want a hardened shim. if the shim goes under the seat isnt it getting the same pressure as the seat? i believe what you are saying is true i would just like to know the reasoning behind it.
I'm glad you got what I was saying. It's hard sometimes to explain something on the internet and it make sense. What makes sense in my head might be complete gibberish to someone else.
Using hardened shims won't hurt and IMO I don't see why you wouldn't use them. It's not like the hardened ones are that much more money.
Going with the 925's now leaves you room to grow especially with the 243 heads you are putting on there. Eventually you will want to put a bigger cam in it. It's just the way it works.
You will already have good heads and good springs on top of that. If you change your cam at a later date you might have to adjust your spring height but that would be about it. Well maybe pushords.
...i have had ls1 cars before so im kind of familiar with the getting used to the power issue. i plan on keeping this car for a very, very long time, so i want to make sure i keep it very streetable.i think im going to order those #4753 shims tonight.
with the radiator, i already flushed it myself at school so im just going to run it and keep an eye on everything. if it even starts to get warmer than it should, im going to shut it down and go buy a new radiator. No point in risking it......... after everything i did i dont want my radiator to take me out
can and will cut into the shim and or head if not hardened. They are a bit
more money which doesn't need to be spent since it's under the locater.
Also to answer LilJays Q. the 1.25 diameter is the standard old school SBC
valvespring pocket size.
i just got home from class and it was here, my seats, seals and locks. im going to go to the machine shop and get some shims from them, they said they would give me 16 for 10$ or 12$. i havnt ordered the comp ones yet so i think im just gonna go that route. im getting excited! its the beginning of the end.
i'll take pictures of the heads when i get them assembled
