Need some opinions guys.
Old Jul 5, 2011 | 09:52 PM
BigBirdLS1's Avatar
Default Need some opinions guys.
Guys my car is in sig and I have been tossing the idea around of adding some heads of some sort. I am kinda on a budget and I have a friend of mine that has a set of I'm assuming to be PRC 2.5 5.3 heads. They are used w/ ~10k miles on them. They did come off of a perfectly running engine with zero problems. I believe they are the 63cc combustion chambers. They are fully assembled ready to be bolted on. They are dual valve springs and yella terra non adj. LS1/LS6 rockers. My ?'s are will there be any issues with running these with such a small cam? What size gaskets should I use I'm not really wanting max. power/compression just a nice street/strip setup that will not grenade itself but pick up some more ponies. He is asking $1300 for them is that a fair price. Also will I have to change my pushrod length and if so to what? Thanks for your help I am not real keen on all these head/cam combos.
Old Jul 6, 2011 | 08:44 PM
Isolde's Avatar
Your sig doesn't give us any clues as to the specs of your cam. So asking about it's compatibility with the proposed heads...
