New Texas Speed & Performance Engine Machining Center!
It's really amazing what you can find out about a block when you can cnc digitize the block & check the blocks actual measurements. I've seen a lot of blocks that require a lot of issues that the cnc machine will allow us to correct!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
