copper valve guides
Old Jul 14, 2011 | 03:24 PM
bugy's Avatar
Question copper valve guides
building heads noticed one valve guide has no clearance with valve, so when valve opens and closes it does some tight, im afraid when it gets hotter it may get that tight that valve does not work as it should, should i drill it out? or it will work just fine?
Old Jul 14, 2011 | 05:03 PM
KCS's Avatar
KCS
Moderator
DO NOT DRILL IT OUT!
Take it to a cylinder head machine shop so they can measure the clearance and hone it out with the proper equipment.
Old Jul 15, 2011 | 01:58 PM
bugy's Avatar
ok won't drill them then, valve opens and closes something tight, and it's only one of them u recommend i do go with specialist?
Old Jul 15, 2011 | 02:24 PM
trans_am7935's Avatar
just take it to a machine shop (particularly one that works with heads) and have them inspect and measure for clearance.
