MS4 on stock pistons?
Old Jul 11, 2011 | 09:30 AM
mattzoom's Avatar
Originally Posted by redracer1
Matt, Datzneat has the MS3 stage 2.5 5.3's w/FAST on his build he put 470+ rwh. You add that 150 shot = money
And sometimes a good deal isn't a good deal
true that
Old Jul 11, 2011 | 10:53 AM
mattzoom's Avatar
Originally Posted by mattzoom
bump for this guy
I am also lookin at these heads- http://s322636171.e-shop.info/shop/a...e.html?pse=apq
thoughts on these heads?
Old Jul 11, 2011 | 01:30 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
Originally Posted by mdeanlittle
matt i have been calling texas speed all week trying to figure out will the stage 2.5 heads work with the ms3 or tsunami cam without cutting the pistons please let me know
Sorry I was out Friday and didn't see this. As long as you order the 5.3L heads specifically for the Tsunami or MS3, they can be setup to clear so you do not have to flycut your pistons!
Hope that helps!
Matt
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Jul 11, 2011 | 02:42 PM
mattzoom's Avatar
Hope that helps!
Matt
thats what im doing ordering the heads cam package the 2.5 5.3L with the ms3
Old Jul 11, 2011 | 02:46 PM
That'll be perfect when ordered together!
__________________
Old Jul 11, 2011 | 02:51 PM
oChristiano's Avatar
Matt Lmk how the set up works out for you. Im planning on a very similar set up for my 96z. Though I was thinking about trying out the polluter but not sure if it'd clear I really don't want to flycut.
Old Jul 11, 2011 | 04:22 PM
Jason 98 TA's Avatar
The MS camshafts are smaller than the Polluter & will have better p/v clearance. The P/V depends a lot on the cylinder head you select when building your combo. We offer a 215 & 227 configured to clear the MS camshafts incase you decide to go aftermarket casting heads!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old Jul 11, 2011 | 04:26 PM
I'll probably go with the tried and true MS cam but off hand do you think your aftermarket casting would clear the polluter? Not much about the polluter and I'm always up to try new things.
Old Jul 11, 2011 | 11:16 PM
mattzoom's Avatar
I will man I didnt wanna flycut either especially cus im running nitrous on stock pistons to I am getting rod bolts tho so it should last a while on a 100 shot
Old Jul 12, 2011 | 02:52 PM
mattzoom's Avatar
hey matt what rear gears a reccommended with the ms3 cam powerband???
Old Jul 12, 2011 | 03:36 PM
Depends on tire size and such too. What tire height (or full size info and I can calculate it) will you be running? Auto or manual transmission? Do you just do street, or lots of racing, any highway time, etc?
__________________
Old Jul 12, 2011 | 03:42 PM
  #32
mattzoom's Avatar
cars never been driven I got it out of a yard and turning it into a drag car, going to be running 28x10 slicks and a th400 with a 4000 stall and a transbrake with a 100 shot if that helps.
Alot of racing and the occasional weekend cruise to meets and car shows around town race weight should be around 3000 lbs maybe 2900
Old Jul 12, 2011 | 04:06 PM
  #33
Looks like a 3.90:1 gear ratio would let you trap 145mph at 6800rpm in 3rd gear. That is assuming no slip though. With that 400rpm stall speed, you could assume about 10-15mph loss up there, so this would get you to around a 130mph trap speed or so. That should do the trick, I think!
__________________
Old Jul 12, 2011 | 07:52 PM
  #34
mattzoom's Avatar
**** 145 trap would be badass this is my first build ever im only 20 so the 130ish traps should be a good start then up the nitrous
Old Jul 13, 2011 | 12:23 AM
  #35
PREDATOR-Z's Avatar
If only it was so easy
Old Jul 13, 2011 | 07:58 AM
  #36
mattzoom's Avatar
lol true that
Old Jul 13, 2011 | 09:28 AM
  #37
Keep in mind though, as stated, 145mph would be with NO slip on that stall and no mph loss to that slip. You can bet on close to 15mph loss!
__________________
  #38
mattzoom's Avatar
bump for this dude
Old Jul 13, 2011 | 09:33 AM
  #39
mattzoom's Avatar
slip? what do u mean im still learning and am new to alot of this.
Old Jul 13, 2011 | 10:12 AM
  #40
bump for this dude
Post #23 that was answered.
__________________
