Lq4 question
Old Jul 12, 2011 | 07:50 PM
Rick364ls's Avatar
Default Lq4 question
I have a late 04 early 05 lq4 it has a crank spacer on the flexplate side is this common? trying to bolt up 400 turbo bolt holes not even close for my converter it is a tci series 7 8inch. It is Out Of a 3500 van
Old Jul 12, 2011 | 08:42 PM
95FbFormula's Avatar
My 04 had the spacer I just pulled off the flywheel and spacer and used the ls1 f body flywheel but I'm using a 4l60e
Old Jul 14, 2011 | 03:51 PM
softballnrd27's Avatar
All the LQ4s that came with the 4l80e had them and you will need the spacer to install your 400. As fars the flexplate you can either order one with the 400 bolt pattern or drill new holes.
