LM7 cam questions
My engine is in an 88 300zx turbo. It has headers, 2.5" y-pipe into a 3" single exhaust, and an ls1 intake. Transmission is a TKO600, rear is a 3.7 CLSD.
How do the car intake and lack of a torque converter factor into my selection of a camshaft? I'd like a little lope, but nothing undrivable. Car is a DD that sees alot of abuse (mostly roll races and general tomfoolery). I see alot of truck guys running TR 220/220 cams (either 112 or 114 LSA). How would something like that work out in my application?
If I'm reading correctly, a lower duration cam makes more power on the low end, and higher duration make more power up top. Any idea what the difference between a 220 and a 224 would be on a 5.3?
http://www.summitracing.com/parts/HOK-2312HKR/
What is the advantage of using the different durations with shorties? Is it to compensate for the lack of scavenging that would be produced if I had LTs?
I have my LM7 in my '85 300ZX, and I also have the 3.70:1 gearing. And I'm using stock manifolds. I'm looking at a 224/224-112.
Comp Cams' online cam thing is suggesting something very similar to the Texas Speed 224/228 on 112 LSA.
I do have an LS6 intake now. Still leaning towards the 224R, likely on the 112 LSA. Hope to make a decision this weekend.
The LS1 intake 97-2000 # is 12560688 it has the EGR ,,,,,,2001-on LS1's got a LS6 intake with #'s 12561184 ,,,,,and the Z06 got intake #'s 12573572 ,,,,,,,,,not sure why if they're both LS6 intakes they have different #'s ? Maybe somebody else can answer that question
I was about dead set on the 224r, but decided to go with the 224/228 as tons of people were suggesting split patterns. There's a few guys running this cam (and larger) in LM7 trucks over on performancetrucks with good results, so I doubt I'll have any issues. At worst, I'm out a few hundred bucks and learn something.
