What next
Old Jul 18, 2011 | 10:13 PM
cory32690's Avatar
Default What next
01 formula 156k a4 4k stall,long tubes to 3in ory to 3.5 dyno max bullet to turndown before axle,lid,85 maf,smooth bellow free mods,sub frame connectors,umi tubular trailing arms and panhard bar,relocation brackets and I've taken roughly 100lbs out of the car
So what's the next best step and still stay my daily driver but I'm also looking for a drop in et
Old Jul 18, 2011 | 10:59 PM
2000PewterT/A's Avatar
A good cam with a intake manifold will be your best option. There are many good daily driver cams out there.
Old Jul 19, 2011 | 05:41 AM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
Rebuild the transmission if you haven't already
Old Jul 19, 2011 | 07:54 AM
cory32690's Avatar
Trans is stock just got two big tranny coolers on it and a temp Gaige to watch it...u think I cam is ok with the high miles i have
Old Jul 19, 2011 | 07:58 AM
senicalj4579's Avatar
Heads and cam.
You dont have a trans cooler yet with that stall? If not you need one.
Old Jul 19, 2011 | 04:54 PM
cory32690's Avatar
no i have two tranny coolers and u dont think with the high miles i have it will be ok to do a cam swap?it just makes me nervous to spin the motor higher into the rpms on the stock bottom end with 156k
Old Jul 20, 2011 | 07:31 AM
cory32690's Avatar
Bump it up
Old Jul 20, 2011 | 07:53 AM
kons02Z28's Avatar
intake and cam let that motor breathe youll feel the power mileage should not be an issue
Old Jul 20, 2011 | 09:39 AM
cory32690's Avatar
Thank you u was thinking torquer v2 and fast 92/92 tune and 255lph fuel pump
Old Jul 21, 2011 | 08:00 AM
cory32690's Avatar
When do I need to upgrade fuel system
Old Jul 26, 2011 | 02:18 PM
kons02Z28's Avatar
probably with cam and intake upgrade fuel pump to racetronics and might better get some 42lb svo injectors stock ones will be maxed out
