cooling fan power wire
Old Jul 19, 2011 | 11:05 AM
mikemunoz's Avatar
Default cooling fan power wire
ok here the thing my cooling fans dont come on,i have check fuses and relays and the same thing. so im going to run them direct. there are to wire white and blue/black. which one is the power wire.
Old Jul 19, 2011 | 11:30 AM
crainholio's Avatar
Pretty sure the black wire is ground, you can probe it with an Ohm-meter to be sure. Should read infinity with one probe on the wire and the other on a good chassis ground.
Old Jul 19, 2011 | 11:39 AM
mikemunoz's Avatar
thing is that none of the fan wires are getting power
Old Jul 19, 2011 | 01:10 PM
Duffster's Avatar
check the relays...
Old Jul 19, 2011 | 01:12 PM
2000PewterT/A's Avatar
Originally Posted by Duffster
check the relays...
Old Jul 19, 2011 | 01:47 PM
mikemunoz's Avatar
i have move the relays around and nothing, OK WELL IM RUNNING THEM DIRECT NOW BUT ONLY ONE TURNS ON, ANY IDEAS WHAT IT CAN BE
Old Jul 19, 2011 | 02:43 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
They are two speed fans and if you do it right you can get both to be on "high" speed. Mine was a HUGE pain in the *** to figure out but I got both on the second speed. I used a relay from a APC fog light kit and it worked.
