EPS 234/246 with L92 heads
I have a stock bottom LQ9 i'm putting together and was planning on using my 243s but they need some work so i would rather just upgrade to L92's.
Has anyone used the EPS 234/246 .602/.607 111LSA cam along with a set of L92 heads? it seems to me like it would work good with the decent split. I already have the cam and would rather not have to purchase another one.
any similar builds out there?
The overlap of this cam is over +17 degree, which you will have a big hickup or surging at the low rpm speed. The L92 do not require that big overlap, and according to alot of threads, the overlap shall not be more than 6 degree and best is lower than or equal to +3.
