torquer v2 installed... greenish fluid leaking... and other problems as well
Old Jul 23, 2011 | 09:42 PM
BIG BILL 2000 Z's Avatar
Default torquer v2 installed... greenish fluid leaking... and other problems as well
torquer v2 cam
fti 3500 stall
shift kit, trans cooler, double roller
powerbond pulley
fast 102 combo
373 gears
im getting a yellowish green color fluid coming from under the car kinda close to my cutout after the ypipe....?
also... my guy who installed all of this said my slp induction plate from my cold air system wont fit back on and i wouldnt need it, he said it would work better anyway??? i dont know about this so give me some answers guys
thanks!
Old Jul 24, 2011 | 03:10 AM
z99ls1's Avatar
Restricted User
Are you sure the fluid isn't leaking from the front of the car and dripping down there. Because that sounds like coolant. Either that or it is gas dripping from your exhaust?
Old Jul 24, 2011 | 03:26 AM
01ssreda4's Avatar
The cold air kit wont fit because of the tranny cooler. There simply isn't enough room because the cold air kits are space hogs.
As far as the drips, remember this, leaks always go down and back (from wind and gravity). Find the highest most forward spot that's wet and there is your leak. Good luck
Old Jul 24, 2011 | 11:36 AM
i thought it was coolant too but the highest point on the ground is under where my cutout is... so then i thought it couldnt be coolant so i was confused.
Old Jul 24, 2011 | 11:37 AM
so are u saying its okay for the induction plate to be out of there? wont my engine get hotter now with that gone?
Old Jul 24, 2011 | 11:59 AM
z99ls1's Avatar
Restricted User
I don't get what "induction plate" your talking about? Could you explain a little more on that?
Old Jul 24, 2011 | 04:47 PM
01ssreda4's Avatar
Take a pic of said plate.
Old Jul 24, 2011 | 11:28 PM
http://rpmspeed.com/product_info.php...sid=llkckpqfju
this is the induction plate im talking about.
Old Jul 24, 2011 | 11:37 PM
z99ls1's Avatar
Restricted User
Why would your engine get hotter if it was gone? The ram air box you posted above is to bring in more air for more power up top. It is an aftermarket mod. It in no way will make your car run any hotter. And like 01red said above, he took it out because it wouldn't fit with your tranny cooler. I kept mine, but it isn't perfectly straight in there anymore, but it works and maybe he said it would work better without it anyway was because he thought maybe more air could get through with not having the box in there. I have also wondered if taking the ram air "box" out would be better or worse...
