Need intake advice
Old Jul 25, 2011 | 05:00 PM
RS_Dmitry's Avatar
Default Need intake advice
Hello I have and LS dropout from a 1999 firebird here is a VIN from this Trans Am: 2G2FV22G0X2229700
I pretty much got everything purchased for the swap (I am swapping it in to a 92 camaro)
And now I need an intake - the problem is I dont know what would be a better fit for this engine - the throttle body (I measured) is 100mm.
Which intake setup would work for me?
I found a couple that I think should fit
Number 1
or
number 2
maybe there are other options?
like a couple of silicone elbows + a pipe and a filter? What diameter then and what kind of filter?
Looking for a best choice.
Thanks!
Old Jul 25, 2011 | 08:22 PM
RARON455's Avatar
If this is a dropout stock engine,,, the throttle body should measure out at around 78mm not 100.
Old Jul 25, 2011 | 09:16 PM
Darkman's Avatar
You probably measured the outside diameter, which is roughly the same for a number of LS throttle bodies. For example the OEM 78mm LS6 throttle body as the same outside diameter of the OEM 90mm LS2 throttle body.
Old Jul 26, 2011 | 09:51 AM
RS_Dmitry's Avatar
Yes I do measure the outside diameter - since the piping will hug the outside diameter. So I just want to make sure which intake setup will fit. Are all of the MAF outside diameters the same as well?
If so then ether kit will work - right?
Old Jul 26, 2011 | 05:37 PM
garygnu's Avatar
get a ls6 intake .I believe jegs sells some silicone tubing.the stock ls1 maf should be the some outside dia.
