Is MTI Stealth 1 just a Comp Cam XE-R?
Originally Posted by J-Rod
Aren't most of MTI cams from Lunati? If so, I would doubt it is an XE-R grind.
Check out page 245 on http://www.compcams.com/Technical/Ca...ML/238-273.asp
What other numbers could you use to identify the cam?
