im missing the low end grunt
my last car was a 79 malibu with a streetable oldschool 383 world heads blah blah, auto, 3500 stall, 4.88'sthe one before that, 90' s-10 RHS headed 383, big cam, dominator carb, auto, 3500, stall, 4.10's and so on.
now 02 hawk m6, 4.56's clutch, no real mods. i guess i just fell into too much interweb folklore, the car runs great, its just not what i was expecting
i gess im just missing the violent throttle burps!!
what to do???
Put a 12 bolt, S60, or 9" out back and a good clutch and go click off some 11 second 1/4 times. High 10's if your short times are in the 1.4's low 1.5's.
Then drive home from the track and get 25mpg on the highway the whole time doing it with a smile on your face while the other guy trailers his home and ran the same times or slower than you did.
That's not internet hype, that's the world of LS motors.....welcome
another ?? can any of you shed any light on why such big intake ports on such small cid engines?? as compared to conventional sbc's, i know they are impossible to compare, lets not start that war,lol
i feel like this has something to do with it, maby not??
To get back to your questions, I assume you are talking about something like mid RPM torque since you specify you like the 4500+RPM performance...
One of the things to consider is that the butt dyno is not a reliable indicator of speed. If you have an older generation type of motor that has a lump of torque that tapers off substantially as it goes towards redline, each time you change gears you will feel a hit and the lack of consistency in the acceleration may actually make it feel faster than it is. On the other hand, a motor that makes good torque and maintains most of it to redline will accelerate more smoothly and perhaps not feel as fast even though it is pulling longer, not necessarily harder.
To answer a little more directly, if you want to improve the torque in the mid range you can do that with the stock displacement with a decent cam and heads choice. Get something with decent DCR and good LSA without excessive advance that will rob the power stroke of length and decrease the torque. You might find that there are a lot of people who want the biggest cam specs just for the sake of having the biggest number. You do not want that... you will want sensible specs optimized for whatever rev range you decide you want to optimize. Likewise, good heads with good flow throughout the valve lift range will be helpful.
6"rod h-beam , 11.75:1, file fit rings, kieth black pistions, RHS 220cc runners, victor JR intake . dominator 750cfm with a two inch carb spacer, .525,.525. /.252@50/ 110* hydraulic flat tappet. lol
all targeted toward top end power, pulled like a tractor on the bottom and loved 7,000,
malibu engine,- same story different cam and intake, dead hooked on the street, like being shot out of a cannon, shiffting at 7,200,auto
i know. antcient technology, but it was dirt cheap, hard to beat around town, as far as getting to the next red light is concerned.
i feel the potential in this car but, will always defend old school powa!!
the car runs well in the upper end, so get it there quicker. start shifting. my thoughts.
lol, i feel ive started a pissing match that cant be won on by iether side,
not ls1 hating people, i just miss the fact that i had minimal money in a old school enging/car set up that makes my fairly expecive hawk feel like its tied to a stump.
GEN 1 hybrids; 400crank=torque & 350 block=better cooling.....but the design
technology of the LS platform is undeniably superior in EVERY way !!!!
Instead of covering the dozens of improvements, I'll just recommend reading
up on what the GM engineers created. Most on this site know that a heads/
cam, & bolt-on combo (matched) will make 500 flywheel HP and still be mild
enough to daily drive while knocking down decent mileage. Lastly peak #s
are impressive in conversation BUT average power throughout the band
gets it done.
some TSP 1 7/8 headers, a TSP true dual setup, and a cam like a TSP MS3 or the TR raptr or trak cam will be a fun ride with 4.56 gears. throw some better heads on that thing down the road and you will have a bad car.
you will fall in love with how the car runs, its luxury compared to old schools, and an AC.
(99 blue bird)
this, exactly!!
AMEN on the AC part. lol
Take that T56 out and put a TH400 or Full manual 60 or 80e. Put a 4000 stall in it, put LT's, ORY, Lid, and exhaust with cutout. T-Rex cam, AI 243 Heads, stock LS6 intake and TB. injectors and hotwire kit. Put a 12 bolt in it with 3.73's and suspension and a LSD. Take the front sway bar off and put a good set of shocks in the front.
If that doesn't pull the tires off the ground every time and get better gas mileage, start every time and have the potential to run mid 10's in that form and with some N20 your in the 9's.
Seriously I don't think the Malibu or S-10 could do that WHILE remaining 100% streetable and not needing a Solid Roller cam 1050cfm dominator and a single plane intake to get there. See where I am going?
I read CHP, Car Craft, Super Chevy, and Hot Rod all the time.
I love Gen 1 small blocks just as much as my dad did.
The Gen III/IV platform is just an all around more efficient better producing powerplant due to it's cylinder head design.
