Darth Vader....Your LSx Stroker is ready!!
Not sure when that will happen (my plate is extremely full right now), but I'm working on the port design as time permits (a little here and a little there....whenever I can steal a few hours). Moving 412 CFM currently and I have hopes of pushing it to 415-420 CFM.....that would be the most flow I have ever seen on my bench (by a good margin), even when I review some of the data from the larger aftermarket LS7 castings I have had the opportunity to flow test.
Good stuff....look forward to the day I slide that bag off the engine and start digging into it again
Cheers,
Tony
www.mamomotorsports.com
Tony@MamoMotorsports.com
Anything worth doing is worth doing well. Build it right the first time....its alot cheaper than building it twice!!
Cheers,
Tony
)I know "Tripper" very well of course having spent alot of time with him working at AFR.....extremely talented Engineer and most things machining and automotive related....truly passionate as well. (And yes....we are both extremely detailed oriented....sometimes to a fault!).
Glad you enjoyed the thread.....Im sure our paths will cross someday....seems like we are close enough and know the same people!
Cheers,
Tony
