water jackets clogged?
Old Aug 3, 2011 | 07:55 PM
O1ws6's Avatar
Default water jackets clogged?
I pulled my head off tonight and saw this…are my water jackets clogged???
also...the tranny is still attached to the block and i cant get to the converter bolts yet. can i just pull the tranny out with the converter still attached to the flywheel?
Old Aug 3, 2011 | 08:43 PM
O1ws6's Avatar
Anyone? Kind of looks like a partial block fill and a pinhole drilled into it??? I have no idea.
Old Aug 3, 2011 | 09:22 PM
Darkman's Avatar
It does looked clogged. The hole may be from steam/water pressure.
Old Aug 3, 2011 | 09:42 PM
chrisfrost's Avatar
Look at the gasket ,,,,,,it has small holes instead of being the size of the block or head . And yes You can seperate the tranny leaving the torque conv connected to the flywheel/flexplate .
Old Aug 3, 2011 | 11:00 PM
SnIpEz's Avatar
The heads have already been discussed, but for your tranny problem, I believe that you need to remove the converter as well, IIRC I saw someone else ask the same thing you did sometime back, I should go back and double check on that
Old Aug 4, 2011 | 04:56 AM
vettenuts's Avatar
Those are just stains on the gasket. When you pull it off you will be able to see into the block although you may need to suck out the coolant to inspect it better. Think you need to keep a closer watch on coolant in the future though, usually the Dexcool blocks are very clean.
Old Aug 4, 2011 | 05:06 AM
mark21742's Avatar
With your starter out, there is one little bolt that holds the plastic sheild the starter snout slides through...take that sheild off and turn the crank so the converter bolt is just below the top of the opening, then you can take it out easily....turn crank and repeat till you have all the converter bolts out
