APE S2 dyno #'s
Old Feb 28, 2003 | 03:52 PM
1BADWS6@STENOD's Avatar
Default APE S2 dyno #'s
I installed my heads/cam and got the car tuned right before Thunder last year, but I never posted the dyno numbers. Here is my set up and dyno numbers. Tell me what you think. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
APE Stage 2 LS1 heads w/ 232/232 .574"/.574" on a 114lsa, Grotyhann 1 7/8" long tubes, 3" dual exhaust, LS6 intake, stock TB and SLP 85mm MAF.
M6, chromoly DS, Moser 9" w/ 4.30 and Detroit locker. Dynoed on 28x12.50-15 ET Streets
385 rwhp/362 rwtq on Mustang Dyno.
<small>[ February 28, 2003, 04:08 PM: Message edited by: 1BADWS6 ]</small>
Old Feb 28, 2003 | 05:09 PM
VINCE's Avatar
Shorty Director
Default Re: APE S2 dyno #'s
I am not going to say those #'s are bad, but I would expect a little more..
Old Feb 28, 2003 | 05:20 PM
LS1derfull's Avatar
How much less does Mustang dyno read than DynoJet?
Old Feb 28, 2003 | 05:24 PM
I8COBRA's Avatar
Those are good #'s with a 9" on a Mustang Dyno.
Old Feb 28, 2003 | 05:41 PM
VINCE's Avatar
Shorty Director
Ooppss, I did not see the Mustang dyno thingy.. Those #'s are great then.. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Feb 28, 2003 | 05:48 PM
LS1derfull's Avatar
Hey Vince how about a rul;e of thumb on difference between dynos? TIA
Old Feb 28, 2003 | 05:53 PM
CHRISPY's Avatar
This is all "dyno" talk but you are down about 30RWHP through the Mustang dyno (Versus dynojet), 18-22 through the 9 inch and ~8 (I think) through the ET streets.
So your numbers are quite good and you should run low 11's high tens in the right setup <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Cheers,
Chris
Old Feb 28, 2003 | 06:22 PM
akw408's Avatar
What is APE? I thought you were talking about ARE, Agostino, but I noticed that you used APE twice so it couldn't have been a typo.
Old Feb 28, 2003 | 06:47 PM
427ZO6's Avatar
A DynoJet will read 5% higher than a Mustang Dyno. In you situation that is 19RWHP. The ET's cost you another 15 RWHP. Combined, that would put you at 419 RWHP on a DynoJet while using regular tires. This is not shop talk. This is from actual experience. Shop talk is free and that is all it is worth.
Old Feb 28, 2003 | 07:39 PM
Thanks for all the replies guys! Alot of people think that APE is just a typo. APE-Automotive Performance Engineering in Clinton Township, MI. They do great work and as you can see they put out some respectable #'s. The best part is their package is very well priced under $3000 for heads, cam, gaskets, and all bolts needed for the install. I went the best of 11.65 @118.54 w/ 1.58 60ft. On this run I was still spinning a bit of the line, so I lowered the pressure down to 8psi. cold. Did my burnout and dropped the clutch at 5500rpms. Went about 5ft. and blew apart my rear u-joint caps <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> Broke the lower adj. bolt on my BMR torque arm also. The car hooked really hard on this run, would have been better than 11.65, but I was happpy with the results! This was the first time to the track since I finished the car, it ran a 11.72 off the trailer and never went into the 12's the whole weekend!
Hopefully after a rear drag sway bar, relocation brackets, Hals and some weight reduction I can see some bottom 11's and maybe 1.50 60fts. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
http://harlan.sketchy.net/hawk/video/kevin_1172.wmv
http://harlan.sketchy.net/hawk/video/kevin_1175.wmv
http://harlan.sketchy.net/hawk/video/kevin_1165.wmv
Kevin
<small>[ February 28, 2003, 08:10 PM: Message edited by: 1BADWS6 ]</small>
Old Feb 28, 2003 | 09:46 PM
LG Motorsports's Avatar
Call me and I will give you a deal on one of our G2 Torque arms. We have cars plling 1.4x 60' times with our Tq Arm.
Call me toll free at 877-LGMotor, and I will knock 20% off.
Later,
Lou Gigliotti LGM
Old Feb 28, 2003 | 10:58 PM
DERTY's Avatar
The Bull
Some of you might remember Kevin's car as one of the cars involved in the double breakout at the Thunder Shootout! His was the white one that broke in the Modified Manual class. I had a good view as I was in the water box at the time! Here's some pics of the damage:
<img src="http://www.derty.org/events/thundershootout/thundershootout02/pics/Thunder%20shootout%20030.jpg" alt=" - " />
<img src="http://www.derty.org/events/thundershootout/thundershootout02/pics/Thunder%20shootout%20032.jpg" alt=" - " />
Good work Kevin!
Old Mar 3, 2003 | 12:38 AM
Stenod's Avatar
LS1TECH Sponsor
Nice numbers Kevin!! Can't wait to see what this bitch does with some weight reduction and a little bit of the happy gas <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> I see 10's in your future <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
And Lou- Can i get 20% off a TA too? i helped work on his car <img border="0" title="" alt="[Razz]" src="gr_images/icons/tongue.gif" /> <img border="0" alt="[driving]" title="" src="graemlins/gr_driving3.gif" />
Joe
