drill the TB hole bigger??
i have been told to do it and not to do it!! i have an A4 and a tr230 cam and rest is in sig and want to know if i should drill the hole out bigger.. it idles great in park but not in gear, at red lights i have to put it in N so it wont start surgin real bad and then die... but like i said, its great in park.. do i just need to raise the idle rpm's while im in gear i think its set at like 850 rpm's i am just tired of having to fight it.. thanks
Have you tried using the throttle screw or what ever its called on the side of the tb? My tuner hates it when peeps drill the hole out lol. BTW, I have the MTI tb with no hole in it. I works fine just using that screw to let enuff air in.
