Oil pressure not rising with RPM
Old 08-15-2011, 10:15 PM
STAR's Avatar
Do you know the engine clearances? I'm guessing you have loose bearing clearances which obviously will effect your oil pressure. Try a 20w-50 with a good filter like a k&n and see how that works. Otherwise an oil cooler will help keep oil temps down and help maintain higher pressure.
Old 08-15-2011, 10:29 PM
01ssreda4's Avatar
Originally Posted by 02blackbeauty19
UPDATE:
I got the timing cover off today and didn't see anything obvious that was "wrong". The oil pump was secured well. The o-ring was perfect. The oil gallery plug was fine. I took the Melling oil pump apart and didn't see anything odd, but this is the first pump I've disassembled. The only issue I see is the timing chain is pretty lax. Here is a video of the chain and you guys can tell me what you think of the slack in the chain.
Here is the video link:
http://www.flickr.com/photos/48008900@N03/6048073964/
While the chain is slightly looser then I would think is optimal, I don't say its a cause for panic. The motor built? Perhaps if they line bored for the crank that moves the crank upward some and creates more slack in the timing?? Also, the double row chains are know for breaking and this may be why...too much slack gets the chain whipping around during operation. A timing chain dampner (LS2 style) would work well here although I'm not sure if they are wide enough to support a double roller. All of that has no effect on your your oil pressure though. I still say replace the pump since everything else has checked out.....
Old 08-15-2011, 10:31 PM
01ssreda4's Avatar
Any particular reason you would be against running an LS2 damper and an LS2 timing set??? Your block is drilled for it I could see in the video.
Old 08-15-2011, 10:48 PM
02blackbeauty19's Avatar
Yeah, I have them on the build sheet. I'm trying to stress that I didn't have this issue before, so it's not the way the motor was built, nor is it the oil temp. Temps of 230-235* are not very high.
I agree on the slack not being optimal. the motor is a forged motor. I wouldn't think that these chains whip any more than a loose single chain. I think most people who have timing chain issues aren't running proper harmonic dampners. This is my original block from my 2002 corvette (LS1), and I have never drilled the LS2 dampner holes. I wouldn't think LME would have either.
Also, I have a new LS4 oil pump on the way. Hopefully it fixes my issue.
Old 08-15-2011, 11:01 PM
01ssreda4's Avatar
The holes are drilled, you got lucky and got a block with them (some 2002s got them). Have you checked to see if its an LS6 block? But, I can see them in your video. They (2) are right above the crank sprocket. No reason not to run a damper.
Old 08-15-2011, 11:09 PM
I've noticed them, just didn't know that the LS2 damper would fit. I really haven't checked the part number because it's never really mattered to me what block it was. LOL I have my stock cam and crank sprockets along with a LS2 chain in box full of other parts. Should I remove this double roller and put that factory stuff back on and order a damper?
Old 08-15-2011, 11:20 PM
01ssreda4's Avatar
Damper may work will the double roller I dunno. I simply don't like the double rollers because when chains break its almost always them. That just doesn't sit well with me. I know your setup is pretty wicked so I would consult someone who is familiar for their TC recommendation. The rate that your engine is going to accel through the rpm band is gnna be punishing for any chain to deal with.
Old 08-15-2011, 11:23 PM
01ssreda4's Avatar
Come to think about it there is a guy/company that is selling the modified ones to work with the LS6 blocks. I should pick up one myself. I forget where the thread is located though as its been awhile.
Old 08-15-2011, 11:27 PM
I thought I've seen something like this, too. Maybe Ill just get a damper and oil pump and button this thing back up LOL
Old 08-15-2011, 11:28 PM
This says it fits ALL GM LS engines
http://www.lingenfelter.com/mm5/merc...egory_Code=C38
Old 08-15-2011, 11:30 PM
01ssreda4's Avatar
I know for a fact there were 2 different hole dimensions (distance from centers) so there is no way that can be right. The LS6 did have a damper available but it is made from unobtainium now.
Old 08-15-2011, 11:33 PM
  #32
01ssreda4's Avatar
Found it.
https://ls1tech.com/forums/generatio...ener-pics.html
Old 08-15-2011, 11:39 PM
  #33
^ Cool, thanks Steve. Ill measure my bolt hole centers tomorrow.
Old 08-15-2011, 11:46 PM
  #34
01ssreda4's Avatar
I never even noticed the holes when assembling my engine I feel like a retard I went back and looked at some assembly pictures and sure enough they are there.
Old 08-16-2011, 10:12 AM
  #35
Welp, I just made an order with LPE for a new C5r timing chain and the cloyes damper.
Old 08-16-2011, 11:44 PM
  #36
01ssreda4's Avatar
Did you have the early style wide holes?
Old 08-17-2011, 01:07 AM
  #37
NBM-LS1's Avatar
Holy **** that is a loose chain! I got a .005 under double roller from the machine shop i used and it has absolutley no slack in either direction.
As far as your oil pressure problem. I was just going through the same problem. My problem wound up being that the front cover of the pump was loose allowing the oil to bleed off easier once hot.
I know you said it was a double roller so did you use any rtv on the spacer for the pump? That is another place to loose pressure.
What size lines are you running to the turbos? any restrictors?
Old 08-17-2011, 07:42 AM
  #38
I didn't use any RTV on the spacers. I didn't notice anything abnormally loose but when thingsheat up and get moving, it can all change. I took the cover of my oil pump off with my 3/8 impact so didn't notice anything there either. I'm really hoping these new parts fix the problem. The good news is that I'm switching back to a stock pump (LS4) and a single chain (C5r), so I won't have to worry about spacers.
I'm running -4 lines to the turbos. No restrictor should be used on journal bearing stuff.
Old 08-19-2011, 11:37 AM
  #39
I took a few pics of the oil plug in the front of the block and wanted opinions. It has 4 makes on it, but I'm not sure if they are there from the installation by the machine shop.
Old 08-19-2011, 05:17 PM
  #40
Bueller....Bueller ???
LOL
Quick Reply: Oil pressure not rising with RPM
