Problems after H/C install, Need help asap!
Old Mar 3, 2004 | 06:18 PM
02WS6#519's Avatar
Unhappy Problems after H/C install, Need help asap!
I just installed ported heads and a cam(224/224 .581/.581 112lsa) in my car. It's an '02 WS6. I keep on getting 2 codes(P0101&P0122). The car dies on me and doesn't want to start for a while afterwards. What should I check for?
Thanks
Ever
__________________
Old Mar 3, 2004 | 06:25 PM
Damian's Avatar
LSX Mechanic
Check your MAF and all the sensors plugged into your TB and make sure everything is good. Those codes are for a MAF and TPS code, so it's something small. Check all those connections....
Old Mar 3, 2004 | 09:22 PM
GrapeApe's Avatar
on the back of the drivers side head there are 3 ground wires that are a bitch to get at --15mm bolt make sure ALL 3 wires are on and that bolt is as tight as you can get it
i had all kinds of codes due to those lil peckers
Old Mar 3, 2004 | 10:53 PM
Slowhawk's Avatar
LS1Tech Sponsor
Looks like you have the MAF and the TPS plugs backwards.
Old Mar 4, 2004 | 01:36 AM
02WS6#519's Avatar
I fixed the problem. The MAP sensor wires were backwards and causing the other sensors to malfunction. Thanks everyone for the replies.
Peace
Ever
