228R Shift Point?
Old Aug 13, 2011 | 08:01 PM
TeeWX's Avatar
Default 228R Shift Point?
I have a 2001 M6, Stock bottom end (stock rod bolts too). Have Long Tubes, ORY, Catback, Ram Air Lid, HPTuners self tuned, other misc things like suspension. I'm installing 799 heads, and a TSP 228R cam with PAC .600 springs over the next couple days.
I was wondering, what RPM should I be shifting at? Right now my rev limiter is set at 6300rpm and on the stock cam I've always shifted at 6000rpm. Should I bump the limiter up and shift at 6400? 6500? What is a safe RPM to take the engine to?
Thanks
Old Aug 13, 2011 | 08:39 PM
01ssreda4's Avatar
6400 would be nice with the limiter set at 6600. That doesn't mean you need to run that rpm every time you go WOT but I would want the headroom incase I needed 100%.
PREDATOR-Z's Avatar
That cam should peak around 6300 with your stock intake so anytime from 6300>6600 would be fine. Look at you dyno runs.
Old Aug 13, 2011 | 09:17 PM
z99ls1's Avatar
Restricted User
Same cam im going with. I think I'm gonna set shift points on mine around 6400-6500 and and rev limiter to 6650.
Old Aug 14, 2011 | 12:40 AM
dodson55's Avatar
id say 6300-6400 would be about right
Old Aug 14, 2011 | 02:49 AM
cowboysfan's Avatar
first you need to find what rpm your hp is peaking at, then try to stay in that area while shifting and accelerating. what I do since my peak HP is 6200 I set my shift light at 6000, because by the time I react and shift I'm about 6400. my rev limiter is set at 6600. stock block. only way to find your peak HP/RPM is on a dyno.
Old Aug 14, 2011 | 02:56 AM
TeeWX's Avatar
Speaking of that. I really need to get a shift light put inside one of my air vents or something. Do you find yours really helpful?
It sounds like I will set my rev limiter to 6600 or so. But does anybody know if there is a "safe" limit as to what RPM you should rev an 01 to?
Old Aug 14, 2011 | 03:21 AM
cowboysfan's Avatar
very helpful. I dont need to look at my tach, I just look at the strip/street and when the light comes on I shift. I have a 01 WS6, and when I shift my 6 speed from 1st to 2nd I dont let off the gas, I let the limiter kickin Idohift it as fast as I can, if I cant get it in 2nd for some reason then I let off the gas peddle.
