PT88 alum block - part failure?
The car is up to about 160* and being a TH400 car, I'm in first @ about 1/2 throttle about 3/4 the way through first gear. I decide to smack it and take off. Well, about a second after I hit it there is a loud POOOF sound from the exhaust - sounds like a lean nitrous backfire would sound coming out the throttle body. Engine goes to 0 RPM. I check the rear view almost expecting to see a trail of oil or parts in the road... but I see nothing. I get it pulled over and pop the hood. There's a small puddle of oil (about 3" round) coming from just under the balancer, looks like the back face of the balancer has oil on it. No obvious holes in the block...
Sooooo I walk back to the house with the wife and son, get my truck and pull the car back home. Get it into the garage and try to crank it, and it turns fine, balancer turns as do all the accessories, but sounds weird... not sure how to explain it. Doesn't sound like a bottom end issue though as there are no MAJOR thuds or banging noises coming from the engine...
Anybody have a guess what's happened? I'm going to start tearing into it later tonight.
Stock crank
Stock LS6 block w/PCV upgrade (valley clearanced)
Forged rods/pistons
ARP hardware throughout
double roller timing chain from SPDC
Stock LS6 camshaft
LS7 lifters
Comp Cams 26921-KIT for springs on 317 heads
I was running about 12psi at the time...
