Cheaper 4' maf housing/ls7 sensor option
Old Aug 16, 2011 | 07:17 PM
1nasty86's Avatar
Turd Gen Guy
Default Cheaper 4' maf housing/ls7 sensor option
instead of buying a tsp, lingenfelter, etc. maf and housing I went the cheaper way.... spectre 4' maf housing 9705 (34.95), ebay ls7 maf (49.95), and an ebay pigtail (21.95)....ends you with this
Old Aug 16, 2011 | 10:31 PM
01cherryreds10's Avatar
Not bad at all. Why didn't you go with the 85mm 5-wire MAF? I originally planned for the 75mm because it was powdercoated to match my TB, but after trying to find a space for the IAT I broke down and got the 85mm.
Old Aug 16, 2011 | 11:08 PM
1nasty86's Avatar
Turd Gen Guy
Because the 4' pipe is close to 100mm which is what I needed.. Inlet restriction KILLS power.
Old Aug 16, 2011 | 11:23 PM
01ssreda4's Avatar
What size is your lid and TB? Or, whats your setup, boost? I can't see crap in your picture.
Old Aug 17, 2011 | 05:41 AM
1nasty86's Avatar
Turd Gen Guy
102mm tb and an airaid cold air from my filter to my tb. Heres a pic before the maf.
Old Aug 17, 2011 | 09:15 AM
themealonwheels's Avatar
Very nice! I spent the $250 on a TSP, but thought it was probably cheaper to make... is that the sensor the TSP and Lingenfelter units use? How well did it tune?
Old Aug 17, 2011 | 09:55 AM
1nasty86's Avatar
Turd Gen Guy
Its a stock ls7 maf sensor same as the tsp. It measures 100mm from inside to inside. And havent got a chance to retune
Old Aug 17, 2011 | 10:13 AM
01ssreda4's Avatar
I see so you've done away with the lid and located the air filter outside the engine bay for cooler IATs?
Old Aug 17, 2011 | 10:15 AM
1nasty86's Avatar
Turd Gen Guy
^^yes.. on the dyno previously the inside shop temp. was 103 my iat was 104.
Old Aug 17, 2011 | 11:49 PM
vnmous97's Avatar
looks great this is why i love LS1 TECH... i will be using this in my project
Old Aug 19, 2011 | 02:11 PM
TPI TERROR's Avatar
looks good
Old Aug 19, 2011 | 02:47 PM
01ssreda4's Avatar
Where did you get the piping to make this?
Old Aug 19, 2011 | 03:21 PM
1nasty86's Avatar
Turd Gen Guy
I bought the actual housing from spectre
Old Aug 19, 2011 | 04:46 PM
01ssreda4's Avatar
No the piping....
Old Aug 19, 2011 | 10:17 PM
1nasty86's Avatar
Turd Gen Guy
Airaid
Old Jan 9, 2012 | 01:08 PM
zacht's Avatar
damn.....finally found it...ive been looking for this thread for a long time...
looking to upgrade my stock stuff...got a 95mm TB with a ported fast now...
good info!!!
Old Jan 9, 2012 | 01:37 PM
5 Liter Eater's Avatar
Does the housing have rolled beads on the ends? I guess for NA, no care, but for those coming in who may be running FI. Good find.
Old Jan 10, 2012 | 04:26 PM
zacht's Avatar
i found some pics of the "9705" spectre setup. doesnt look like it has rolled ends...but i dont think it would be hard to score a few grooves in the ends...or put a bead on it. not to mention if you use 2 clamps (t-bolt) it should hold plenty of boost.
Old Mar 16, 2013 | 05:23 PM
2000ws6transam's Avatar
hummm for the price i might give it a try...
Old Mar 16, 2013 | 06:24 PM
96capricemgr's Avatar
How hard was it to get the airflow tables dialed in?
