2002 LS1 (used) knocks on first startup
Old Aug 18, 2011 | 09:25 PM
DerrenC's Avatar
Default 2002 LS1 (used) knocks on first startup
I'm trying to resolve a knock in my engine. I've been getting help from members at TGO in this thread:
http://www.thirdgen.org/techboard/lt...ns-knocks.html
but maybe my questions more appropriately belong here.
That thread chronicles how it sounded wrong when it first fired:
and how I ended up pulling the heads (after pulling the pan and checking rod bearings) to find this:
The rings looks to be intact, and there is a wide shallow gouge on the cylinder wall opposite the piston damage. Valves appear fine.
So my question for experienced LS1 owners is this: As bad as that looks, would it cause the knock heard in the video?
Old Aug 18, 2011 | 11:28 PM
c0ncEpT's Avatar
It more than likely has something broken in the valvetrain. Sounds just like my buddys car when a rocker lost all the needle bearings.
All the cars I have seen lose a ringland have ran decent -1 cylinder. My friend drove his car 70 miles home from the track with a broken ringland. Other than a slight miss and a back fire it ran as quiet as before.
Old Aug 19, 2011 | 08:52 AM
DerrenC's Avatar
So far the valvetrain looks fine. I pulled the rockers and pushrods and they were fine. I pulled the heads off to replace the lifters when I found the busted piston.
I figured I had found my problem, but yeah, I wondered if it would actually cause a knocking noise or not.
Has anyone ever had a busted piston like this cause a discernible knock from the engine?
