Need input on a cam (yes, I read the sticky)
my experience with stall converters and the stock 4l60e..
4000 stall speed
transgo "full race high stall" shift kit
b&m 24gvw cooler
i put 40k miles on this setup, sold the car, and it is still on this setup with a total of over 60k miles. i made over 300 passes at the strip (low 1.6 60' spinning on a stock bent tq arm), lord knows how many street launches, a few 3rd gear rev limiter burnouts and thousands of miles driven to drag strips around the state, where i raced.
if you aren't a total moron with the stock **** it will last. if you already have 323s, don't both swapping gears. 373s aren't worth the $/gain and anything steeper will put you in OD before the traps with any amount of power, which is not good on the trans, at all.
4000 stall speed
b&m 24gvw cooler
It might, it might not. If its going to go its going to go... Larger converter or stock.
To ensure your trans probably won't break you could build your trans or move to a built 3 sp.
You mod, **** break, period. Better get use to that fast. It is a very expensive hobby. You upgrade one thing, you have to upgrade or strengthen a minimum of 3 other things in most cases, aka supporting mods.
Restricted User
Just get a 3200 converter and a 224r and b done. Back when I had my lt1 when I was in highschool and I had the same rules where my dad didn't want me doing anything to the car. I bought the stuff and put it in when he wasn't around lol. Ur dad might be different, but mine usually found out about the mods later and thought it was cool lol. I did install a 2600 stall and a hotcam in my old lt1 car when I was 16. The cam he knew about the stall he did not. Now im 20 and I have to keep myself from modding and going broke lmao. BTW if the trans shop near you says a high stall converter will tear your trans up than they are ******* retarded lol.
Well how does the trans shop get around cars stalling when they put them in drive ? I would not recommend you doing these mods unless you know what your doing haha. Lemons 3spd? that would be good to drag but not daily drive!
9 second lt1 easy add 2 turbos
You have never seen a car with an auto trans and big cam stall when you shift from park to drive? My dads truck used to do it all the time because he had a mid 230s cam (cant remember lift and lsa) but every time he wold shift form park to drive it would stall because the rpms drop when you put it in gear, now he has a 3000 stall and everything works great.
