forged rods/pistons for my stock ls1?
We can set you up with H-beam rods with 8740 rod bolts and Diamond pistons for your assembly including the rings for $1199 or with the 2000 bolts for $1249. Take a look at our group buy as well, It is $2349 for a Diamond piston, H-beam rod, assembled balanced short block in a LM7 Iron block built to 346CI. This would be a GREAT replacement that will be done and ready to install.
https://ls1tech.com/forums/sponsor-g...s1-1799-a.html
The TSP set up is great as well. If you go that route they are an awesome place to deal with and the recommendations John has made will make a great addition.
In my opinion you should look at the Wiseco flat top pistons, and an eagle 6.125" H-beam rod with the ARP 2000 Rod bolts. This setup from us comes in at $1249.99 and I know both parts can handle that kind of nitrous no problem. I would also recommend looking at doing an ARP main stud kit at the same time you do this other work. It would leave you with a bottom end that should be rated to around 900.
Why flat top? Wouldn't you want lower compression for spray? I was under the impression dished Pistons lower the compression.. Still learning could be wrong.
