Dart Pro 1 Heads
like your stock head I run this head c n c ported it is a good head.
run the ls2 head gasket, and you have to trim the rocker stands no big deal.
There are zero oil consumption problems. The hype was propagated with a few people who basically ruined the heads with "prep" work and posted online how they didn't work right.
Call Dart. They got some of these heads back and did a big WTF check. It was all consumer error. They work great for me.
know. Back in the mid 70s he would horizontally cut AMC heads through the
intake ports(1 set 1/4" above mid port, 1 set 1/4" below mid port) then braze
weld the taller upper and the taller lower to make a hybrid runner cylinder
head that when ported would flow enough air to support well over 750 fwhp
from a 354 cubic inch small block tunnel rammed with a pair of 660 center
squirter holleys. Again MID seventies....WTF. The guy ain't no dummy !!!!
