Best Heads for a 408 ci
I also thought about whether you had enough injector. IIRC LS3's are 42lbs. so if you are running a set of those you are ok. Still may want to check the pump to make sure you are ok there.... I just went ahead with a Wahlbro to be on the safe side but I honestly do not know what a healthy stock pump will support...
If you can post the dyno sheet that may be of help....
EDIT:Clarification.... LS3 injectors are 42lbs. @ our 58psi
I will work on the tune within the next few weeks. I do have LS3 42lb injectors in there. The tuner didn't even change the injector data for the LS3 top end. He left them stock 36lb in the tune when I got it back. I'm sure there are lots of hiccups like that in the tune i'm running.
plus cfm those heads flow has less than ideal port-speed for the weight of a
truck. If small runner AFRs or TrickFlows aren't in the budget then maybe
some AI 317s w/FAST would help create a flatter torque band.
a vehicle thats a thousand pounds lighter with gears. If you're also thinking
of changing out the cam perhaps an EPS 226/230
Having a small intake runner doesn't magically make gobs of torque come out your engines ***.
I know what builds torque...especially at altitude. But take it straight to the horse's mouth. Call AFR. Give them the vehicle, weight, gearing, intake hardware, exhaust, cam specs, rockers, etc. See what they recommend. They would know best.
I would keep the LS3 heads and get em ported along with a FAST 102..
408 cubic inches will eat up just about any head available. Then your plastic intake will be the restriction. Which is good.....then you can upgrade the intake later when you have more cash, but get the best flowing heads possible that $$$ allows.
Don't just get what everyone else has that has a 408ci...........
