Whats head on a Lq9
Old Sep 7, 2011 | 01:06 PM
Chaos07's Avatar
Default Whats head on a Lq9
What kind of heads/cam do yall usually run with the LQ9 setup?
Old Sep 7, 2011 | 04:01 PM
usmcz28's Avatar
I'm running LS3 heads with my LQ4, you may be able to get away with it as well but have to check the PTV clearance.
I know ported 243's go real well with them too.
Old Sep 7, 2011 | 04:54 PM
cutlass_455's Avatar
I got ls3 heads on mine. I had to fly cut cuz my cam is big.
Old Sep 7, 2011 | 07:17 PM
Chaos07's Avatar
What the ls3 head what kind of power are yall putting down, i was going to use a either a stage 2.5 ls6 or Lq9 head from Texas speed
Old Sep 8, 2011 | 10:30 PM
A.R. Shale Targa's Avatar
GM puts LS3 heads on a 4.065" bore Min. to help unshroud the 2.165" Intake
valve. Stay cathedral for more average torque.
Old Sep 9, 2011 | 05:53 PM
SNLPerformance's Avatar
Depending on your goals, an LS3 head will limit the size of cam you can run without flycutting because of PTV clearance. Feel free to contact me and I can help you get in the right h/c package. Can even do the work/tuning if you feel like a roadtrip.
Chris, 817-750-2000
Old Sep 13, 2011 | 10:11 AM
My LQ4 with LS3 top end just made 415rwhp. This is pretty good considering the low compression, that got even lower when I fly cut the pistons to make room for the cam.
Old Sep 13, 2011 | 10:14 AM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
For bang for the buck a PRC cnc ported LS6 head is hard to beat.
http://www.texas-speed.com/p-1391-pr...ted-heads.aspx
If your looking to spend some extra $$ on a aftermarket casting the PRC all new aftermarket casting LS3 heads features smaller than stock (250cc) runners, better p/v for larger camshafts, and smaller chambers. All of these features while moving 360 cfm!
Another great option that I would really consider is the PRC 227 small bore heads. You can setup the heads with smaller runners for big compression & still run a healthy camshaft unlike milling stock style cylinder heads!
Not to mention they're also on special!
http://www.texas-speed.com/p-1163-pr...der-heads.aspx
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
