Please help!! Missing over 50rwhp after G5X3/LSX intake install! Dyno graph inside.
Old 03-09-2004, 04:51 PM
  #81
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,175 Likes on 764 Posts
02 sensors
MAF
Did you recently pull the heads off? If so crap washed down the header pipes perhaps.
Old 03-09-2004, 04:53 PM
  #82
SPANKY LS1's Avatar
Were your heads ever flowed to .600+ lift?
Old 03-09-2004, 05:02 PM
  #83
2000Blackout's Avatar
I believe he is running the stock injectors still.
Old 03-09-2004, 05:04 PM
  #84
verbs's Avatar
02 sensors
MAF
The o2 sensors were a bit slow, but the Ltrims were never positive, so no extra fuel should have been dumped in at WOT.
I swapped my MAF for another one and there was no difference at all. Dead on. Louis of LG suggested checking the plug itself as they've had a few problems with that.
Yes the heads were pulled off to flycut and to repair the 7 bent valves I had.
I have flow #'s up to 600 lift, and my heads kept pulling in more CFM all the way to .600 lift. HOWEVER!!! Maybe something I need to consider is port stalling. I know some of the early TEA heads had port stalling problems around .550 with the LS6 intake attached. My old cam only had lift to .576, so maybe I didn't see that much of an affect, but if these heads are stalling, that could be part of the problem.
.100 72.2 55.0
.200 141.6 105.2
.300 205.6 151.5
.400 254.6 193.4
.500 290.1 231.0
.550 300.4 247.2
.600 306.2 260.4
Originally Posted by gomer
Verbs,
Hey I tried to PM you, but your box was full earlier. It's kinda off subject, but are you still using stock injectors? If not, what are you using.
Thanks
box is empty, stock injectors.
Old 03-09-2004, 05:08 PM
  #85
verbs's Avatar
Here is a dyno graph showing my dyno pull today vs. my dyno pull at this same shop with the old setup. The A/F ratios were identical on both, between 12.8 and 13.0 the entire way.
The differences are:
Old setup had 230/224 cam, comp 987 springs, 3.73 gears, 10.8:1 compression, ls6 intake, stock waterpump, no YT rockers
New setup has a G5X3 cam, Crane 832 dual springs good to .650 lift, YT rockers, Meziere pump, port matched LSX intake, and about 10.6:1 compression.
As you can see I'm down about 40rwtq down low, and a good amount of power throughout most of the graph. Now notice how my new setup peaks at 6200rpms or so, and it's supposed to peak at 6400-6500 rpms per LG. Maybe there's just a hint of valvefloat because the power does stop a bit short.
Attached Thumbnails Please help!!  Missing over 50rwhp after G5X3/LSX intake install!  Dyno graph inside.-new-setup-vs.gif
Old 03-09-2004, 06:11 PM
  #86
Coal Mining Director
onfire's Avatar
Are you sure the LG cam is better than the Thunder cam? Anybody else exchange one?
Old 03-09-2004, 07:03 PM
  #87
LSX Mechanic
Damian's Avatar
Again.....
Was your valvejob recut after replacing those bent valves?
Old 03-09-2004, 08:21 PM
  #88
gomer's Avatar
Originally Posted by Damian
Again.....
I was thinking the same thing.
Old 03-09-2004, 09:54 PM
  #89
Krazy98Z28's Avatar
The first thing that popped in my head was the TEA Heads. When i posted my dyno numbers with the 232/236 .595/.602 cam everyone said it was my heads and I was told to stay with a higher intake duration and lower exhaust duration and to keep the lift around .570ish. I know this sounds like a pain in the *** but i would swap cams back and see the difference. I never got the chance to swap cams cause i sold the car. I dont think those heads like that cam, dont get me wrong 430 RWHP is killer but not for what that cam is capable of.
  #90
99 Black Bird T/A's Avatar
Received 1,451 Likes on 1,007 Posts
Since the valves have been replaced the old flow numbers don't really mean much IMO. Quality valve job & correct angles makes or breaks any set of heads.
Who installed the replacement valves? Did they flow the heads after the new valves were replaced to make sure they were flowing like they should? If so what were the new numbers? Were the old heads were flowed with the LSX in place to determine if any port stall occured?
BTW-What's peak lift for that cam?
Old 03-10-2004, 01:15 AM
  #91
AZ Power & Sound's Avatar
If the shop in question did his head repair I wouldnt trust them, they are also the ones that put 2 broken spark plug wires back on the car and couldnt figure it out... Glad I get to fix someone elses work His setup feels strong as hell but I Think there is a LOT more in it, but with the 4.10s the tach is sooo far behind that you cant really tell what RPM your shifting at accuratly until 3rd and 4th, and with his exhaust its a lil loud to be doing those kinds of speeds on the street! We have almost identicle cams, mine with stock LS6 heads and his with TEA 5.3s... and while his does feel a little faster, it also has twice my mods and 4.10s versus my 3.73s, and his car is close to 150 lbs less so tough to do a SOTP feel... I just wish I knew what the shop really did or didnt do because that would make life much easier!
Old 03-10-2004, 10:09 AM
  #92
verbs's Avatar
they didn't do the repair, the outsourced to a cylinder head specialist in town
Old 03-10-2004, 11:27 AM
  #93
can you get a printout of the work performed?
Old 03-10-2004, 12:16 PM
  #94
verbs's Avatar
Again.....
they tested the valve seat for pressure by using Serdi Machine (which is how they found the bent vavles), and did a valve job only where the valves needed replacing.
Old 03-10-2004, 12:41 PM
  #95
Restricted User
2001 Pewter WS6's Avatar
You could swap cams in 3 hours. Swap it back and see where you are at. This would alliviate a lot of guess work.
Old 03-11-2004, 12:57 AM
  #96
2000RATA's Avatar
This is not the problem if they even stall.
Chris
Old 03-11-2004, 04:48 AM
  #97
Brian Tooley Racing's Avatar
You gotta be kidding me, I tell everyone never to let anyone mess with the VJ on those heads, or any other we do, and people do it all the time and then are down on power and wonder why, and then they said they only cut the seats with the bad valves??? I think you just took one of the best sets of 5.3 heads to come out of here and killed em.
Old 03-11-2004, 07:56 AM
  #98
verbs's Avatar
I talked to Brent numerous times about my situation, he knew I bent valves, but he never said a word to me about that. I wish I had known.
Old 03-11-2004, 09:35 PM
  #99
GrannySShifting's Avatar
We have the same looking graph, g5x3 cam, peaked at 6000-flatlined to 6300 then droped like a rock. Was making 436 at 6000 RPM. Looking at the rockers first (loosen them up) then maybe valve float.
Old 03-11-2004, 11:10 PM
  #100
verbs's Avatar
I put the stock rockers on, nothing gained down low but maybe a bit up top. Dyno #'s will reveal all soon enough.
Quick Reply: Please help!! Missing over 50rwhp after G5X3/LSX intake install! Dyno graph inside.
