Once again another compression question....
Old Sep 9, 2011 | 12:23 AM
01 WS6 6.0's Avatar
Default Once again another compression question....
Ok so ling story short i have a PTV issue with the stocl ls1 so its now gone. Buying a motor from a tech member and he said compression should be around 12:1 compression its a 408 iron block 65cc chamber heads with daimond flat tops with if im not mistaken an .049 gasket will this be streetable I WILL BE DRIVING THE CAR EVERYDAY. Ive done some research that with a proper tune it is possible but i dont want any problems later down the road. I do plan on spraying the motor. Will this be safe a pump gas 93 octane. I've always heard to keep it around 11:1 my head guy said i will probably have problems running this comp on the street daily.
Piston Specs:
Bore: 4.030
Stroke: 4.00
Comp Height: 1.125
Efffective Vol: -1.8cc
Cam 293 LR 243/251 624/624 114*
Thanks
Jose
Old Sep 9, 2011 | 01:35 AM
01 WS6 6.0's Avatar
Anybody
Old Sep 9, 2011 | 07:17 AM
RsSean's Avatar
With the right tune yes it can be street driven. Mines 11.8 I was driving it for a long time on the street. Cheap gas could cause dentnation tho
Old Sep 9, 2011 | 08:15 AM
farmington's Avatar
with a cam that big, you could probably skate by, just use good, name brand 93 octane, and keep a bottle of octane booster on hand in case it starts rattling.
Old Sep 9, 2011 | 11:50 AM
01 WS6 6.0's Avatar
I considering on tossing this cam and having one custom ground would this be a good idea? Also getting rid of my rapTR. Should i go a little thicker head gasket as well?
Old Sep 9, 2011 | 09:07 PM
chrisfrost's Avatar
Have You considered adding a water inj system ? Im not real knowledgeable about those but I believe they also work great at cooling down N/A engines allowing higher compression and/or timing advance without pre-ignition which equates to more HP . Similar to a cold air intake but even more cooling .
