oil leak/consumption
Old Sep 11, 2011 | 04:46 PM
ozzyls12001's Avatar
Default oil leak/consumption
do you know where does this oil come from??also my car is recently build up,its a 383 ,with PRC ,Trex cam,fast92/92 and all bolts on i also have a catch can,im having oil consumption ,like 1 liter /1000km ,thanks!
http://www.youtube.com/watch?v=YNZ6RMtasko
Old Sep 11, 2011 | 05:25 PM
LilJayV10's Avatar
is it smoking any? I was using a lot and found the wrong valve seals were installed on the heads. I'm running dual valve springs.
Old Sep 11, 2011 | 05:36 PM
hi,im also using Livernois dual valve springs, the car is not smoking or something,could be something or leak in the PCV system?thanks!
Old Sep 11, 2011 | 11:00 PM
09camaro383's Avatar
i don't think you have the catch can install correctly i see your fresh air hose connected to the catch can
Attached Thumbnails oil leak/consumption-1catch1.jpg
Old Sep 11, 2011 | 11:29 PM
chuckd71's Avatar
Did changing the valve seals help?
Old Sep 11, 2011 | 11:33 PM
LilJayV10's Avatar
The car is apart right now. Waiting on the valve spring compressor tool. The car smoked at start up occasionally and when I let off after WOT. It has all the symptoms of being valve seals. That coupled with there being chunks of the seals and some of the seals pulled up off the head I think it will. I will post back after I get it back together one way or the other.
Old Sep 11, 2011 | 11:41 PM
camaroz28lt1at's Avatar
Start with upgrading to a LS6 valley cover and hooking up your catch can correctly.
Old Sep 11, 2011 | 11:47 PM
LilJayV10's Avatar
That's a lot of work.
edited as I didn't see you mentioned the catch can.
Old Sep 11, 2011 | 11:48 PM
LilJayV10's Avatar
You are correct. It's routed wrong. Good catch.
There is also oil sitting in the corner of the intake.
Old Sep 11, 2011 | 11:51 PM
thank you very much! i think i didnt install right,i will correct it ,thanks for the diagram bro
Old Sep 11, 2011 | 11:52 PM
i change valve seals like 1 year ago could be the valve seals?i will change anyway
Old Sep 11, 2011 | 11:54 PM
does the camaro 2001 doesnt have the LS6 valley cover?your right,i will install my catch can correctly,thanks !
Old Sep 12, 2011 | 12:11 AM
LilJayV10's Avatar
https://ls1tech.com/forums/generatio...outing-ok.html
It's a long read but here's a good thread on catch cans if you haven't seen it.
Old Sep 12, 2011 | 12:51 AM
Quick pic of mine with the LS6 valley cover.
Attached Thumbnails oil leak/consumption-imag0088.jpg
