need cam help
Old Sep 12, 2011 | 01:14 AM
wayne33's Avatar
Default need cam help
Ok folks I have a 68 camaro, 3100lbs, 10 bolt 3:73's posi. I know I will have to upgrade my rearend in the furture and add 4:11's
now I'm putting a ls1 with 799 heads, ls6 intake, ls2 timing chain, fresh rebuild, lt headrs, ported TB. I'm going to go with a t56. the car is a weekend warrior maybe one day a year at track. I never want to lose to a stock stang/ import.
but I need help picking a cam that has great lobe for classic sound but will give me a great performance. Ive heard a torque V3, 228R AND LOVED THE SOUND.
WHAT DO YOU GUYS RECOMMEND?
Old Sep 12, 2011 | 01:26 AM
z99ls1's Avatar
Restricted User
Ms3 FTW.
Old Sep 12, 2011 | 01:40 AM
wayne33's Avatar
Just for my education why would you go with ms3 over ms4? thanks for recommendation.
Old Sep 12, 2011 | 03:37 AM
jermzz's Avatar
less lift, better for valve springs. Plus from what ive seen ms3 makes same or better mid range numbers then the ms4 while the ms4 may sometimes make better peak. Mid is more important.
Old Sep 12, 2011 | 04:08 AM
wayne33's Avatar
Thanks for comments Now will the ms3 be better than some of the comp cams out ther
Old Sep 12, 2011 | 04:26 AM
Johnnystock's Avatar
Its not necessary lift that determines how tough it is for the valvetrain; the lobes itself plays a bigger role, I think.. LSR, LSK etc..
With 4:10 gear and light car you can go with a bigger cam...just get a good tune. TV3 is a good choice too. Lots of other good cam in the 230 range..search a lot!
Old Sep 12, 2011 | 12:31 PM
wayne33's Avatar
@ johnnystock I've searched so many posts i have a list of cams and dont know which will be the best for my taste. there are too many choices.
Old Sep 12, 2011 | 05:39 PM
z99ls1's Avatar
Restricted User
So post up all the ones your looking at and let us help you make a decision Btw you know about texas speed and performance right? I would really relally recomend getting your cam kit from them with some prc doubl springs and your choice of pr's. They have great priced kits already put together for you! + great customer service and they are on ls tech alot.
Old Sep 12, 2011 | 06:29 PM
wayne33's Avatar
@ Z99LS1 Ive tried to call them today like 4 times just rang and rang
SO FAR I LIKE THE SOUND AND PERFORMANCE FROM:
1)MS3 lsa 112
2)torque v3 lsa 112
3) EPS 230/234 .600/.601 111lsa
Old Sep 13, 2011 | 11:47 AM
wayne33's Avatar
anyone like one of these more than the others
Old Sep 13, 2011 | 12:35 PM
s346k's Avatar
dbl post.
Old Sep 13, 2011 | 12:36 PM
s346k's Avatar
i'd go for something in the mid 230s/low 240s on a 112-114 lsa. something similar to a g5x3 either 112 or 114. with a 410 gear and that weight, the car would roll out hard.
i'm not a fan of the ms series of cams. they don't seem to have very good midrange and fall off quickly after peaking.
Old Sep 13, 2011 | 05:35 PM
wayne33's Avatar
everytime i look up g5x3 i cant find anything where is the best place to buy it?
Old Sep 13, 2011 | 06:27 PM
SNLPerformance's Avatar
Our V4 cam is a 230s cam on a 112, it makes great average power in a 346 and will compliment a set of ported heads down the road should you so choose. Feel free to call me with any questions you may have. Chris, 817-750-2000
Old Sep 13, 2011 | 06:29 PM
s346k's Avatar
wayne - check classifieds here or lgmotorsports. it is an lg specific cam that i'm pretty sure has been on the market almost 10 years. a very proven cam.
specs seem to fall somewhere in the 234/242 range on the x3 utilizing comp xer lobes or something similar. nothing crazy, just a proven cam that has been around for years.
Old Sep 13, 2011 | 11:05 PM
A.R. Shale Targa's Avatar
Streetsweeper or Tsunami....flip a coin
Old Sep 13, 2011 | 11:53 PM
01ssreda4's Avatar
Most importantly, what kind of rpms are you wanting to shift at?
Old Sep 14, 2011 | 01:12 AM
wayne33's Avatar
im not sure what rpm i will shift, but i do want nice power thru out
Old Sep 14, 2011 | 01:50 AM
01ssreda4's Avatar
Yeah but we need to know what "throughout" means....
Old Sep 14, 2011 | 02:00 AM
z99ls1's Avatar
Restricted User
Most cams mentioned above will have to be shifted at 6600rpm plus
