Bad cam eats lifter, need help choosing new cam!
Old Sep 21, 2011 | 01:54 PM
adham's Avatar
Default Bad cam eats lifter, need help choosing new cam!
I have a 2001 Corvette Z06 and recently had a bad aftermarket cam mess up a lifter. I don't know how the cam would be bad but that is what I was told (heat treat or something). So I'm installing new LS7 lifters and now I'm trying to decide on a new cam. I have full bolt ons, headers, catless x-pipe, Ti catback, vortex ram air intake and underdrive pulley.
I would like to make power close to the 420 mark which shouldn't be too difficult since I have the LS6 heads and intake manifold. As far as driveability, it's not my DD but I would still like it to be tolerable, I don't mind if it shakes at idle. I do like the sound of a mean idle with a nice lope.
My main concern is the powerband. I don't want to rev the car to 7000 rpm to get to the power.
I've been looking at cams from TSP because they seem to be within my budget. I really don't have any specific cam in mind so any suggestions would be great!
Btw, heads are stock LS6 and I don't want to flycut them or modify them.
Thanks for the help
Adham
Old Sep 21, 2011 | 02:05 PM
99Bluz28's Avatar
M6 or A4 trans?
Old Sep 21, 2011 | 02:24 PM
adham's Avatar
Originally Posted by 99Bluz28
M6 or A4 trans?
Sorry, M6
Old Sep 21, 2011 | 02:52 PM
BStowers023's Avatar
Sounds like any cam around a .600 lift exhaust/intake and a 230-240 duration will work and as far as the LSA you want 112 or under and it will have a nice lope to it.
Old Sep 21, 2011 | 02:58 PM
adham's Avatar
yeah that sounds about right, do you know which off the shelf cam might resemble that?
Old Sep 21, 2011 | 03:08 PM
Bramlok's Avatar
With your stock heads the TSP 228r 112 LSA would work nicely. Great power all throughout the powerband without having to rev it sky high. Great drivability, easy to tune, mean choppy sounding idle on the 112LSA.
Old Sep 21, 2011 | 03:23 PM
SNLPerformance's Avatar
Our V4 cam is in that range and makes great average power on a 346. Feel free to contact me with any questions. Chris, 817-750-2000
Old Sep 21, 2011 | 07:59 PM
adham's Avatar
bump
Old Sep 21, 2011 | 09:06 PM
99Bluz28's Avatar
If you main concern is power band, you'll probably want a duration under 233*.
Old Sep 21, 2011 | 10:18 PM
01ssreda4's Avatar
Who cut the failed cam for the vendor? Comp Cams I bet
Old Sep 21, 2011 | 10:30 PM
adham's Avatar
exactly
Old Sep 21, 2011 | 10:36 PM
adham's Avatar
Thanks for the input!
I'm not too familiar with the cam sizes, duration and lift etc....can you tell me which number is what? For example, if there is a 232/234 .595"/.598" cam, which number identifies the duration, the lift, etc?
Thanks again
Old Sep 21, 2011 | 10:52 PM
01ssreda4's Avatar
Originally Posted by adham
exactly
Well, I hate to dog on Comp because they are a super high volume joint. Of course they are gonna have some failures based on the sheer volume they produce on a daily basis. But that is one reason I chose a Cam Motion grind (they grind their cams in house), it was recommended to me by some LS geared vendors that Comp's QC had gone down the *******.
Old Sep 22, 2011 | 03:01 PM
adham's Avatar
friendly bump
Old Sep 22, 2011 | 04:32 PM
01ssreda4's Avatar
duration lift then lsa
Old Sep 22, 2011 | 05:10 PM
adham's Avatar
got it! thanks
Old Sep 23, 2011 | 01:25 PM
adham's Avatar
ok, I'm thinking of choosing one of the two cams:
TSP 233/239 .595"/.603"
or
TSP Torquer V2 232/234 .595"/.598"
both on a 112 LSA
I want to go a little bigger than a 228 because that's what the previous owner said is in the car right and I think I'd like a bit more.
Old Sep 25, 2011 | 12:25 PM
blazer427X3's Avatar
I am running the 233/239 from TSP (112 lsa) in my Z06. It hits pretty hard at around 3300rpm. I like it !
Old Sep 25, 2011 | 12:46 PM
Whiteaw57's Avatar
233/239 FTW I just put a 238/240 112 LSA in my Camaro and love that too
Old Sep 25, 2011 | 02:31 PM
adham's Avatar
Thanks for the responses!
How's the idle and driveability? How much power are you putting down?
