LS Valve Train Noise Sucks! I challenge the aftermarket.
#61
I am currently replacing my Comp Cams XR275H12 cam with a EPS/LXL cam. I am hoping against hope that it will be better. Geoff sent me some 7.425" pushrods to complete my collection. Although with the taller height of my LS7 lifters, this will put preload in the .130"+ range on my stock short-block and un-milled LS6 heads.
To give you an idea of how loud it is, when I drive by a building or a car in traffic, I can hear lifters/valve train noise above the sound of anything else from my car. It sounds terrible and it is so annoying to me that I sound deadened my floor and firewall to keep it out and I can still hear it coming through at times.
If this new cam does not work, I have an offer to try some new lifters. I really don't want to pull the heads again and I don't have a lot of time for that right now, but it is the only next move I can think of if the cam does not quiet this thing down.
#64
After the install of my EPS/LXL cam from my previous Comp (XE or XER or something along those lines) and installing the factory style foam strips to my Fast intake my noise is virtually gone. It's still there, but no where near as bad. It's more the sound of the valves closing as Shane pointed out but I do have some sewing machine noise.
I am running 7.4 pushrods on Vortec 350 roller lifters with 799 heads milled .010" and FelPro stock thickness gaskets. If I did it right, I am just shy of 2 turns under 0 lash so I would really like to try some shorter pushrods.
I have a pushrod length tool so once I get some free time I am going to measure and see what it thinks I need.
#65
You are forgetting maybe the most important factor...and that is lobe design.
#67
Vortec rollers
#68
I had sewing machine when I went cam only & stayed with 7.4 pushrods....As has been stated..'attention to detail'. Now with shaved heads, higher comp, different cam etc etc & better attention to detail, & a Fast intake I have a relatively quiet valve train.
edit: Just noticed you listed comp trunion upgrade. Just maybe you need adj r/rockers to get your valve train quiet, good quality shaft mounted Jessels.
#69
LOL. Here we go again.
I appreciate that your statement is based on your personal experience, but there are others with a different experience including many very reputable sources that have measured and photo documented their findings. If you search you can find the other threads.
#72
Speedtrigger, I understand what you're saying. I have two short stories about some of my cars. I did a cam swap in my '97 Corvette using a Comp 228/230 588/592 on 112 LSA
This thing was dead quiet, I remember guys telling me to buy new lifters, but I didn't because my car only had 30k miles. Of course it wasn't fast enough, I swapped on a set of 5.3 heads and broke down and bought the Caddy lifters. Guess what? Noisy valve train. Preload and pushrod size were correct.
Next boring story, I have a 2002 WS6 with 14k miles. The valve train isn't nearly as quiet as the 99 106k mile WS6 I just bought. I remember thinking, man I bet this thing is going to have lifter noise. Nope, not a single sound comes from the higher mile engine, it has long tube headers too.
Back to the Vette, I'm not sure what specific change accounts for the noise, but I can tell you it sure wasn't the camshaft. I don't remember the lobe profile though. Either way the same cam was in the car.
This has me wondering when the lifter design changed.
#74
Got some more miles on the new setup so to chime back in with my EPS 230/238, high end of tolerable preload, FAST90mm, longtubes, and older Vortec 350 lifters mine is nearly silent when warmed.
I do have a slight noise that seems to get louder based on load coming from the passenger side of the engine, I can only hear it if the windows are up and the radio is off. It could be an exhaust leak I haven't checked yet. Could also be one of the lifters making a little noise.
#76
i haven't read all this thread but i can vouch for the eps cam once i sorted my **** up with the oil pump its as quiet as before i tounched it and sounds the bollocks i would rekomend a esp cam all day long
#77
In my opinion, changing lifter preload is not going to get rid of the noise unless your way off. As it has been stated here over and over again, its the ramp rate of the lobe that makes the sewing machine noise. I beat my head aginst the wall with mine measureing and remeasuring my lifter preload, buying three sets of push rods, and hours of research, and guess what? I still have valvetrain noise. My cam has a XE-R lobe so it's noisey and always will be. The only way I'm going to get rid of the noise is to swap the Cam.
#78
#79
Many great answers in this thread. From what I have learned in many years of working on this particular engine family, is that valvetrain noise is such a "common" thing in where stock parts have been replaced with aftermarket parts. What OIL PUMP is in your engine?
#80
