Need new heads
MASS seller approved
depends on budget. to get most of that cam are some good heads. if you only got around 450 for heads, then 243s are best. if 1,000, some cnc ported heads from here from a member, if 1300, prc heads. if 1800, ai, tea or used afr 205s.
just keep in mind:
you get what you pay for,
the end results you want,
if eventually ai, tea, you can start with the 243s and save for their work later on,
and we come back to your budget...
hope this helps.....good luck with your project, Rob.
just keep in mind:
