Rocker "tap?"
Old Sep 29, 2011 | 01:37 PM
redbird555's Avatar
ALmost sounds like a bend pushrod? Has it been overreved lately eitther way best thing is to tear open the valve cover and find out
Old Sep 29, 2011 | 02:02 PM
98blkz28's Avatar
Mine was reved high lately, my friend's car was broken into and I went after a van who came into the neighborhood with lights off and turned around when they saw us. so yea
Old Oct 3, 2011 | 04:34 PM
CHADsterss's Avatar
Ahhhh I just figured it out! My #4 spark plug was extremely lose... Now the problem is getting to it so I can tighten it properly, I got it as tight as I could with my hand in the super small space I just don't know how long it's going to hold up.
Old Oct 4, 2011 | 02:02 PM
98blkz28's Avatar
I just changed all my spark plugs and cables...and rockers.. The sound is even worse now..checked the push rods if they were bent they were only slightly..idk if that would make a huge difference. but either valves, spun bearing, or something.
98blkz28's Avatar
http://www.youtube.com/watch?v=NnpQj...el_video_title
Old Oct 4, 2011 | 02:24 PM
bene's Avatar
Trunion King
If they're bent don't use them.
Old Oct 5, 2011 | 02:27 AM
98blkz28's Avatar
is there a more precise way to tell besides rolling them on the floor or on something? bc it was super hard to tell if they were bent but I guess I can get a hardened set ad put those in and try it. if they were only very slightly bent would it cause that bad of a noise?
Old Oct 5, 2011 | 11:00 AM
OldCobraGuy's Avatar
You know what I would do? I would kill one cylinder at a time and see if that changes your noise. If it's a header leak, that would show it. It also might give you an idea as to what cylinder is causing the noise if it's another issue.
Old Oct 5, 2011 | 11:17 AM
98blkz28's Avatar
I totally did not even think to do that, that is way easier then me running the car without the valve covers to see if its the rockers.. I'll try that and if there is still a noise..I try the harder method lol
Thanks!
Old Oct 6, 2011 | 11:00 AM
CHADsterss's Avatar
Keep us updated!!
Old Oct 6, 2011 | 04:58 PM
98blkz28's Avatar
Thanks!
So i tried this today.. no results. still the horrible knock...um thinking its prob valves, pushrods, or something else.
Old Oct 7, 2011 | 09:19 AM
  #32
No change in noise at all? If that's the case, that has an upside. It's not a rod or piston (unless they are actually broken and there is no compression on that cylinder)
Old Oct 8, 2011 | 09:08 AM
  #33
HVYMTL's Avatar
That last video sounds exactly like mine when my pass. side header gasket blew out. I used the crap ones that came with my headers (stupid I know...) and they had cracked and pieces literally up to and inch long had blown out from between the head and flange
Old Oct 8, 2011 | 09:09 AM
  #34
HVYMTL's Avatar
whoa, woops. didn't realize there were two pages. I was referring to the last video on page 1, lol
Old Oct 11, 2011 | 07:39 PM
  #35
98blkz28's Avatar
so this is what i have now going on
http://www.youtube.com/watch?v=hbY7clSDzN8
Old Oct 11, 2011 | 08:35 PM
  #36
CHADsterss's Avatar
That sounds like a spun bearing to me...
Old Oct 11, 2011 | 09:00 PM
  #37
redbird555's Avatar
ya man bearings are done. As to why thats a toss up. Could be that you overrevved it and the bearings took a crap, maybe the bearings were starved from oil for a sec and thy went that way, or the 98 is known for its weaker rod bolts maybe they stretched and it went that way.
Either way pull the motor rebuild it or get another and replace the pushrods..
Old Oct 11, 2011 | 10:14 PM
  #38
98blkz28's Avatar
It's good to finally have a definite answer.. Thanks everyone!
Old Oct 11, 2011 | 11:20 PM
  #39
Anthony Williams's Avatar
That my friends is a flattend cam lobe and lifter roller. Been there, done that. It's the reason I had to do this-
https://ls1tech.com/forums/generatio...-swap-top.html
Old Oct 11, 2011 | 11:44 PM
  #40
Do the cheap first,
Pull the heads and lifters, then you can inspect the cam and lifters, if the lifter rollers and or cam are in anyway pitted or flat, replace all of the lifters and the cam (would do the pushrods too since it's already down) provided everything else was good before the noise (oil press, temps etc.). If the lifter and cam are good then your already about a 1/3 of the way through an engine pull anyway. But I'm 99% sure its a flat cam lobe/lifter roller BTW mine ran fine and the oil press was great but it sounded just like yours, the neghbors thougth I had bought a diesel. Good Luck!
