Budget head/cam build that's CA smog legal?
Ok so swap the pushrods for a pushrod length checker, and order pushrods after I know the length. Does everything else look good? I probably should've added this is going on a car with 111k miles on it.
Lol yeah that's what I'm trying to avoid.
Just for reference,
I did the TR224 on 114LSA, PRC stage 1 milled .02" through an aluminum intake at 380rwhp and 375 tq. Decent numbers as long as the TR224 passes as suggested.
IMO, get the stock heads milled and ported or buy some AFR 210's. You can still fail the visual even with gm heads if they check the numbers and the don't come up for your yr & model. I'd also would go with a cam that has more exhaust than intake duration, like the Tick Performance Emissions Friendly Cam or the Thunder Racing CheaTR v.3 or TR TRuTorq Level 1, and there's also the Lunati Voodoo # 20540713. http://www.tickperformance.com/tick-...1-ls6-engines/
IMO, get the stock heads milled and ported or buy some AFR 210's. You can still fail the visual even with gm heads if they check the numbers and the don't come up for your yr & model. I'd also would go a cam that has more exhaust than intake duration, like the Tick Performance Emissions Friendly Cam or the Thunder Racing CheaTR v.3 or TR TRuTorq Level 1, and there's also the Lunati Voodoo # 20540713. http://www.tickperformance.com/tick-...1-ls6-engines/
![Burnout](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_burnout.gif)
I think you would really like our cam OP. Although it hasn't been used in quite as many applications as the CheatR cam has, @.050 the cams are nearly the same. I don't know if the CheatR cam has any advance ground into the cam or if they recommend advancing it, but mine does have 2 degrees ground into the camshaft itself.
Martin, I think your cam would work good for his application, plus those lobe should be fairly quiet adding to the stealth factor. I do think he could probably go with a little less exhaust duration if he goes with higher flowing heads, a good example would be a 218/226 115lsa+2 which would still have -8*OL and have slightly better low-end.
IMO, get the stock heads milled and ported.a lso would go a cam that has more exhaust than intake duration, like the Tick Performance Emissions Friendly Cam or the Thunder Racing CheaTR v.3 or TR TRuTorq Level 1, and there's also the Lunati Voodoo # 20540713. http://www.tickperformance.com/tick-...1-ls6-engines/
