crank and rods
Old Sep 29, 2011 | 05:06 AM
lemkerailroad's Avatar
Default crank and rods
i am going to use the 5.3 crank that i have as it only needs to be polished, i am building a 5.3 engine and am going to punch it to a 5.7 spec,
will the 5.7 rods work without mods??????
i would like to get h beams if all possible but want to make sure that they would fit the journals of the crank
dave
Old Sep 29, 2011 | 10:15 AM
parks450's Avatar
You can use the 5.7 rods. If you go aftermarket most rods require aftermarket pistons too.
Old Sep 29, 2011 | 10:32 AM
Callies Performance's Avatar
Compstar has a 6.100 rod with the std. pin, so that you could use the stock piston.
http://www.racingjunk.com/Rods/22992...00-2.100-.html
