LM7 with LS1 parts...
LM7:
Complete stock take out
Intake
Heads
manifolds
Block
Waterpump
Oil pan
Ls1
Complete top to bottom
Harness custom integrated to work with the BMW E36 chassis
Stock injectors and rail
Corvette filter/reg
Standard fuel pump
PCM was sent out for VATS remove, rear o2 remove, EGR and vent valve remove; driven with this pcm already
Stock cam from what i can see
Crank bad, 2 rods bad
New custom one wire alternator
New car waterpump
Standard P/s
Cold air intake
Standard oil pan
Bad oil pump
Transmission:
T56
Pro 5.0
stock ls1 clutch
What worth installing in the LM7, if anything beyon the oil pan, headers, and intake manifold? Will i be able to exhange the intake rails, injectors, and run the stock ls1 tune for now, until i can get it tuned for the fewer cubes? Is it worth swapping heads?
LM7 running with intake and exhaust
http://www.youtube.com/watch?v=fJADyOk6a4s
LM7 Exhaust with revs. There was standing water in the catback from when i sat it outside standing up. Its 1.75" 28" long tubes, 3" collector, 2.5" step down, dual bullet cats, xpipe, dual BMW M roadster catbacks.
http://www.youtube.com/watch?v=DVvMqoQ-fSs
LM7 Fuel and Oil pressure testing, open headers.
http://www.youtube.com/watch?v=nMffMJnREVs
oem ls1 harness, standalone fuse panel, and an e36 x20 plug
http://www.currentperformance.com/shop/stand-alone-fuserelay-module/
