Springs for EPS 226/230
Old 10-19-2011, 01:47 PM
  #41
SweetS10V8's Avatar
What lift are you running, what is the coilbind height of the springs?
You know coilbind is the absolute hardest spec to meet for a spring manufactuer right? Its the thing that varies the most and can still be called "in spec".Typically they will only be allow to vary lower, and not higher than the spec.
Edit: I looked up coil bind on 921s, its supposed to be 1.040". Plus .060" for standard optimal distance to coilbind equals 1.100.
1.720-1.100 = .620 lift, this is what that installed height would be optimal for(Assuming every spring actually coil bound at 1.040").
Old 10-19-2011, 06:57 PM
  #42
LilJayV10's Avatar
My lift is .600. I sent the springs off to be checked and Shaned mocked them up and checked for me.
Quick Reply: Springs for EPS 226/230
