Pushrod Q:
Old Oct 12, 2011 | 02:44 AM
z99ls1's Avatar
Restricted User
Originally Posted by ZeeOSix
The spring pressures are based on the spring's rate (lbs/inch) and the spring deflections.
The closed pressure is dependent on the spring's installed height, and the open pressure is dependent on the max valve lift (ie, max spring compression).
Coil bind has really nothing to do with the seat pressures, but strickly on the max expected deflection. At the max valve lift, there should be at least 0.060" clearance between the remaining open coils - and this should definitely be checked on the car.
Choosing the right springs is mostly dependent on the max expected valve lift to ensure there is no coil bind, and that the springs are stiff enough to prevent valve float with the cam profile at max expected RPM.
Thanks for the info! Thats why I'll be going with the .650 prc dual springs for my 228r.
Old Oct 12, 2011 | 08:56 PM
mannyman84's Avatar
That's what I got.
Old Oct 12, 2011 | 09:04 PM
z99ls1's Avatar
Restricted User
Awesome what cam did you go with? Are you auto or 6-speed?
Old Oct 13, 2011 | 12:35 AM
mannyman84's Avatar
The ms3. 6 speed.
Old Oct 13, 2011 | 01:15 AM
z99ls1's Avatar
Restricted User
Originally Posted by mannyman84
The ms3. 6 speed.
NIce, that's a big a$$ cam! How many miles do you plan on putting on the springs tell you replace them?
Old Oct 17, 2011 | 11:55 AM
FlamingTA's Avatar
Does everyone tighten down the rockers to 22ft lbs? I have read in a few places to tighten them down to 24-26. I am doing my measuring and checking the wipe pattern right now with my AFR's and Yella Terra rockers. When I tighten them down to 25ft lbs I get 1.4 or so turns with 7.425 known length TSP pushrods with LS7 lifters. It looks like that is good, about .065 preload. Not sure I want to go up to .090 preload.
Old Oct 17, 2011 | 01:11 PM
ZeeOSix's Avatar
The service manual calls out 22 ft-lbs, but I'm sure 25 ft-lbs would be OK.
