LS2 blocks
Old Mar 9, 2004 | 02:40 PM
granitemonkey's Avatar
Default LS2 blocks
Wont the new LS2 blocks be able to handle more bore than a LS1??
Old Mar 9, 2004 | 03:18 PM
1fastWS6's Avatar
I'm pretty sure the LS2 block is a 4.00" bore versus the LS1's 3.90" bore. Maybe someone else can verify.
Old Mar 9, 2004 | 04:45 PM
bad2000ss's Avatar
I believe the LS2 has the same bore and stroke as the LQ4/LQ9.
Old Mar 9, 2004 | 10:45 PM
WhiteDiamond's Avatar
The new LS2 block is a 4.00 bore, but they are still using cast in place liners. I wouldn't expect to be able to do much more than a clean up hone on the bores.
Todd
Old Mar 9, 2004 | 11:36 PM
Mike00FRC's Avatar
Nice thing is that with a 4" stroke crank you'll get 402ci vs the 382 in an LS1 without touching the sleeves.
Old Mar 10, 2004 | 01:16 AM
rons 00z's Avatar
when do you guys think this will be available?
