Does my engine build plans sound good for 400+rwhp?
• 2002 stock block brand new + .005 honing
• Stock Crank-turning? $200
• Forged Diamond pistons-$600
+tool steel or stainless Rings-$200
• Lunati forged rods+wrist pins+rod bolts-700?
• Stock Rocker Arms?
• Bearings-?
• Balance Motor-$500?
• ARP Head studs-$200
• ARP Main studs-$200
• TR Oil Pump-$130
• GM Gaskets-$200
• Lifters-$200
• Timing Chain-Katech-$170
• Comp Pushrods-$110
• Heads Stage 2 GTP-$3000
• Cam TR 224-$375
• QTP Headers+Y-$1000
<small>[ March 02, 2003, 01:20 AM: Message edited by: andy98Z ]</small>
• Bearings-?
• TR Oil Pump-$130
• GM Gaskets-$200
• Lifters-$200
• Cam TR 224-$375
Re: Does my engine build plans sound good for 400+rwhp?
loks good but no way idpay 200 for gaskets, NAPPA now has em for 14.95 shipped, if you cant get in yopur area lemme know and ill hook ya up, no reason to pay that much for gaskets.
-I was just estimating..but i didndt know they good be obtained that cheap
-do u have any split duration cam recomendations?
Thanks guys-
Thanks guys-
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by BYBYC5:
<strong> loks good but no way idpay 200 for gaskets, NAPPA now has em for 14.95 shipped, if you cant get in yopur area lemme know and ill hook ya up, no reason to pay that much for gaskets. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I spent 200 on misc gaskets through out the motor. But if your spending 200 on the head gasket get some cosmic. Expecially if you plan on spraying it
ALbert
ALbert
Looks Like at Real STELLAR SOLID set up! Just make sure you use ARP Rod Bolts to complete the bottom end as i didn't see them on the list but probably overlooked it. Should be good for close to 430rwhp!
Good luck,
MTI 427 C5 Roadster
Good luck,
MTI 427 C5 Roadster
My guess is that without the bottle, it should run in the low 430RWHP range, which is fairly stout. Sounds like a interesting peice, keep us updated. Would love to see some dyno sheets once it is all together. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
